CB350/400
400/4 Oil Filter
Topic: 400/4 Oil Filter (Read 4353 times)
Golfcarmad
SOHC Associate
400/4 Oil Filter
February 26, 2019, 03:47:05 PM »
Nearly there with complete rebuild.
In putting oil filter etc back on,Haynes shows a Metal spacer between end of filter and engine.
I do not have this,nor does there sem to be room.
Anyone comment/advise please?
Also,had to change swinging arm from F2 to F1,cut off footrests,when I put back wheel on-right hand side spacer (twice length of left hand) pushes the swinging arm out a little too much for my liking.Could be my eyes!! Again,anyone had similar issue please?
Thanks n regards
Paul
More bikes than sense!!
Honda 400/4 (almost fully rebuilt)
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Honda CBR500F (Import)
Francis Barnett Plover
Puch Maxi 2 speed (makes me smile)
Cb100n cafe racer
50cc scooter (now does 52 mph)
hairygit
Re: 400/4 Oil Filter
February 26, 2019, 04:26:14 PM »
The spacer you refer to is a shim/washer that is around 1mm thick, often you'll find it stuck to the old filter (if you've slung the old filter you'll need to get another one!) It basically forms a seat for the spring that fits on the filter bolt between the filter housing and the filter. I certainly wouldn't run an engine without it.
Golfcarmad
SOHC Associate
February 26, 2019, 04:50:57 PM »
Thanks,1mm or so I can sort,picture in Haynes looks more like - 40mm,so thank you for advice.
I do have old filter,nothing stuck,but I wwill go through "parts over so far" box and check.
Regards
Paul
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
Trigger
February 26, 2019, 05:27:07 PM »
The big spacer is for the 350 four or are you trying to fit a 350 four oil housing to a 400 four
Golfcarmad
SOHC Associate
February 26, 2019, 08:55:28 PM »
Hi again,I am refitting the correct oil filter case to the engine.i have: bolt complete with o ring inside bolt appears to be a cylinder,spring held in place by a through pin.i have the outer casing,a new filter which has a rubber seal at each end.and finally a large diameter spring .thats it!that is what was fitted.what if anything am I missing please?
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
Nurse Julie
February 26, 2019, 09:08:43 PM »
Sounds like its No. 76 that's missing
Nurse Julie
February 26, 2019, 09:12:08 PM »
Golfcarmad
SOHC Associate
February 26, 2019, 09:21:19 PM »
Hello 1 x idiot here,I had put the washer onto the rear axle under the castellated nut!!!
Thank you,about to put oil and start engine inside conservatory-a bit late tonight maybe.
Apologies
paul
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
Golfcarmad
SOHC Associate
February 26, 2019, 09:26:32 PM »
Latest photo
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
Nurse Julie
February 26, 2019, 09:37:23 PM »
Honestly, under the castellated nut, different
What's the story with the wiring?
Golfcarmad
SOHC Associate
Reply #10 on:
February 26, 2019, 09:43:13 PM »
Just attached to check engine turned over-which it does.
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
Nurse Julie
Reply #11 on:
February 26, 2019, 09:43:59 PM »
CB350/400
400/4 Oil Filter
