Author Topic: nogo  (Read 11318 times)
Offline Andy1976
  • '76 Honda CB750F1
nogo
« on: August 02, 2008, 11:37:52 AM »
I'm still struggling to get my bike started.
I have done/checked - carbs,cleaned out jets
                               fresh fuel
                               new plugs with correct gap
                               batery checked and ok
I'm unsure about checking electrics, all the wires seem ok and conected properly.
              Andy
Re: nogo
« Reply #1 on: August 02, 2008, 05:06:13 PM »
Does it fire/misfire/spit/pop at all?  If not then check the 12V side of the ignition.
Are the plugs wet? If so you have fuel so that's one thing off the list as fuel + spark = bang (even if it is a misfire)
If plugs dry then no fuel so check to see what you put back into the carbs upside down...  ::)
Off to France tomorrow on my Sprint so won't be posting (much).
Re: nogo
« Reply #2 on: August 02, 2008, 06:17:28 PM »
Have you checked for a spark, pull a HT lead off put a spark plug in it, ground it against the cylinder and turn the motor over (kill switch), you should see a spark, as Steve has said wet plugs show that fuel is getting through. You need sparks, that's plugs, coils and electrical trickary, the spark has to be at the right time, points and timing. Is there any power at the points. You need fuel from the carbs, is it coming out of the tank, are the float bowls filling up, you also need air (in the right place), how is the air filter and carb rubbers.
Den
Offline Andy1976
  • '76 Honda CB750F1
Re: nogo
« Reply #3 on: August 03, 2008, 01:38:45 PM »
I've been outside this morning working on the bike. It's only sparking on no.3 theres nothing on the others. Since cleaning the jets, no.2 carb is leaking fuel everywhere. The float bowls were full when I took them off.The plugs don't seem wet (no.3 seemed damp), but they do smell of fuel. Maybe a complete carb overhaul? The battery is reading 12.35v so I think this is ok. The ignition system is electronic by Boyer Bransden, should I go back to points system? I also noticed two of the carb rubbers from the airbox have small splits on them, the inlet rubbers seem in good nick.
      When I tried to start it before it made a popin noise and also a huge backfire (scared the crap outa next door ;D).
         I think I'll be ok sorting out the carbs but electrics arn't my strong point.
                   cheers
                   Andy
Re: nogo
« Reply #4 on: August 04, 2008, 09:44:43 AM »
Hi Andy, what is the history of the bike, was it running when you got it ?
It would probably be a good idea just to do a basic service on the bike, valve clearances, timing, carb set up etc just to make sure that the basics are correct. Sparks are paired, 1&4, 2&3, if you have a spark on 3 you should have a spark on 2 as well, what condition are the HT leads and plug caps, what plugs have you got.
Den
Offline Andy1976
  • '76 Honda CB750F1
Re: nogo
« Reply #5 on: August 04, 2008, 04:22:52 PM »
Hi Den, I got the bike in September last year. It was running lovely and it rode nice too. There was'nt much history with the bike, just a couple of reciepts for a new battery and brake pads and an MOT slip. I have had it re-bored and new pistons fitted(it broke down six months ago).
      When you say valve clearances, do you mean the gap between the tappets? The HT leads seem ok but I've noticed a chunk missing from no.2 plug cap. The plugs are NGK DR8ES and D8EA (only jus noticed two different types!)
     I have taken off the carbs to give them a good clean. I have found a good reference on the other site which should help with settings.
         Thanks mate
          Andy
Re: nogo
« Reply #6 on: August 04, 2008, 04:43:53 PM »
Yep, valve clearance, tappets, 2 inlet 3 exhaust if I remember correctly, the other site should have loads of info that you can use, sure helped me rebuild my F1.
Den
Offline Andy1976
  • '76 Honda CB750F1
Re: nogo
« Reply #7 on: August 05, 2008, 08:12:39 PM »
I'm going to re place the spark plugs as the others were mis matched. Two were D8EA and the other two were DR8ES-L(NGK). The manual says to use D8ES(NGK) or X-24ES (Nippon Denso). What plug would you recommend I use?
Andy.
Offline Dave M
Re: nogo
« Reply #8 on: August 06, 2008, 07:42:51 AM »
I've always used NGK's.
« Last Edit: August 07, 2008, 09:35:21 PM by Dave M »
Dave
Melbourne.
Re: nogo
« Reply #9 on: August 06, 2008, 04:43:45 PM »
That's a good question, I always used NGK D8ES-L, but they you can't get them anymore, so I got D8ES-L R, these did not work they fouled up very quickly, so I tried D8EA,s, these were better but still fouled. Then I read a thread on the other site in which Hondaman recommended the ND X-24ES-U, I now use these and they appear to be fine.
Den
Offline dave400
Re: nogo
« Reply #10 on: August 07, 2008, 09:34:52 PM »
You dont need resistor plugs "R" if you have resistor spark plug caps.....what plug caps do you have?
Dave
« Last Edit: August 07, 2008, 09:36:34 PM by biffta »
Offline Dave M
Re: nogo
« Reply #11 on: August 07, 2008, 09:35:54 PM »
I'm running resistor plugs and caps with no probs.
Dave
Melbourne.
Offline dave400
Re: nogo
« Reply #12 on: August 07, 2008, 09:42:08 PM »
Why add more resistance in the circuit than is needed, 5k? is what Mr Honda decided was enough why double it?
Dave
Offline Dave M
Re: nogo
« Reply #13 on: August 08, 2008, 09:12:16 AM »
The resistor is there to prevent intereference on tv's and radios etc. and I couldn't get the non resistor plugs so I asked the question on a couple of forums (here as well I think) and the general concensus was it would be OK.
It's running fine on them and I don't cause any interference on anyone's telly or radio.
Dave
Melbourne.
Offline Andy1976
  • '76 Honda CB750F1
Re: nogo
« Reply #14 on: August 10, 2008, 02:04:48 PM »
Hi Biffta, these are my spark plug caps. I'm not sure if they are resistor or not.
 There is a number, XD05F 5K?. As you can see one has rubbers missing, will this affect it in any way?
Plug cap NO.2 is damaged so needs replacing.
