Author Topic: Carb flooding  (Read 4892 times)
Offline masonmart
Carb flooding
« on: March 13, 2019, 07:14:11 PM »
Tried to start my Dresda 500 today but on turning the petrol on found it flooded out of the overflows. Will take them off tomorrow to have a look at the floats and needle valves but any thoughts on what else I may need to look at?
Many thanks
Dresda CB500-4, 605 cc
CB-77, 350 cc
1968 Bonneville
1976 Thruxton Velocette
1974 Kawasaki Avenger
1997 VFR 750
Offline davefirestorm
Re: Carb flooding
« Reply #1 on: March 13, 2019, 09:28:13 PM »
Could be float needle valves not seating properly a common problem on Superdream carbs and Quick is heady fix is to remove float bowls/floats/ needle valve and use a cotton bud with solvol autosol to lap the face where needle valve seats,thouroughly clean and blow out after.
Honda CB650Z
Honda F6C Valkyrie
Offline matthewmosse
Re: Carb flooding
« Reply #2 on: March 13, 2019, 10:44:10 PM »
Common on cb500/4,  mine was almost always sorted by redex or  a light tap on the side of the carb with a soft  handled screwdriver. I cannt think that I ever took the carbs off as redex added neat in the fuel pipe was the most involved fix I ever needed to do. Seemed to crop up every 6 months or so when the bike was my only transport and racked up some serious milage.
Offline masonmart
Re: Carb flooding
« Reply #3 on: March 14, 2019, 06:01:48 PM »
On other Japanese bikes when one out of 2 leaked I used to take off the bowl and let fuel flush through the needle valves or just tap the carb with a driver but these are all seeming to leak. The redex tip is interesting, never heard of it.
CB-77, 350 cc
1968 Bonneville
1997 VFR 750
Re: Carb flooding
« Reply #4 on: March 14, 2019, 07:20:35 PM »
They sell it in lots of places, eg Tesco's, Asda and poundland all carry it. Comes in different types though I'm not sure of the differences but it's basically an additive for fuel, Personally I have had great success with it, both the diesel formulation which I used in my 4x4 dumper that was getting cranky to start - not good news on a hand cranked diesel but pre dosing it with redex you could crank all day if the temp was under 10°c and if wouldn't start, after a dose it now starts first try right down to freezing.
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: Carb flooding
« Reply #5 on: March 18, 2019, 08:46:33 AM »
I can get the bowls off in situ using a torx right angle handle with a long screwdriver tip in it.
Used carb cleaning kits off eBay. One is little brushes and the other is tiny abrasive wires.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Re: Carb flooding
« Reply #6 on: March 18, 2019, 09:03:38 AM »
Don't stick anything like brushes or little rasps through jets, it ruins the inside of the jets and upsets everything. Soak jets in carb cleaner and blow through with compressed air.
Re: Carb flooding
« Reply #7 on: March 18, 2019, 02:00:03 PM »
I would leave carbs in situ take tops and bowls off and squirt carb cleaner in and blow out with air line.I replaced the cross head bolts with 4mm stainless hex socket caps for easier removal/refitting
Honda CB650Z
Honda F6C Valkyrie
Re: Carb flooding
« Reply #8 on: March 18, 2019, 08:39:28 PM »
agrees with Mathew.
 regular use of REDEX will keep it clean ,
