Author Topic: 550 K1 Carb Help please ( Update )  (Read 2733 times)
Offline jon stead
Re: 550 K1 Carb Help please
« Reply #15 on: March 26, 2019, 05:17:20 PM »
Is it all four spark plugs that are shooting up, or one or two? If two, is it 1 and 4 or 2 and 3?
Have you confirmed your exhaust pipes aren’t partially blocked?
Davelu88
« Reply #16 on: March 26, 2019, 05:55:32 PM »
Hi its all four plugs , no i have not checked exhausts for blockages but i wouldnt have thought i would have a blockage in all four pipes or maybe im just very unlucky and i have  :( , however i contacted Gerben as these were a set of his carbs and he politely replied stating that the 087A carbs should have a 38 slow jet & these have a 40 in them so would that be enough to cause the over richness
« Reply #17 on: March 26, 2019, 07:54:38 PM »
I may have to go back and check figures, but I've got the 38 jet at 15.38% less area than the 40 jet.
So flow should be a noticeable difference to jetting.
When you adjust slow speed jetting and get no/little response in "normal " screwdriver adjustment range, then it is suggesting that the engine is "asking" for a different jet size to bring it within normal operating settings.
It does look like it needs the smaller jets.
Davelu88
« Reply #18 on: March 26, 2019, 08:02:38 PM »
Thanks K2  ;D
Davelu88
« Reply #19 on: March 26, 2019, 10:06:25 PM »
Definately says stock is 38 on these carbs , Question is how much difference would this make ?
Davelu88
« Reply #20 on: March 26, 2019, 10:22:37 PM »
yes i believe the pipes do go to the bottom of airbox , , after googling 087A carb specs it states 38 slow jet i have also messaged Gerben who built the carbs and he agrees that these carbs have a 38 slow jet , & looking on CMSL site the K1 & K2 both have 38 jets although the 500 does have 40 , so not sure why the 550 has a smaller jet.
« Reply #21 on: March 27, 2019, 10:31:33 AM »
You can replace the slow jets with carbs in situ. Allen screws make it easier to remove the bowls.
Davelu88
« Reply #22 on: March 27, 2019, 09:50:43 PM »
Have ordered 38 jets will let you know if any difference is made  ;D
« Reply #23 on: March 28, 2019, 08:24:37 AM »
Looking forward to that. I have always wondered if it really makes a big difference.
Davelu88
« Reply #24 on: April 03, 2019, 05:21:10 PM »
Just a quick update on my carb issue , the 40 jets have been changed to 38 carbs balanced etc & it seems to idle , run ,accelerate ok , did a chop test on plugs and although a bit sooty they are nothing like they were so fingers crossed all ok . Many thanks for all the help on here.
Cheers Dave
Offline Raymond_Y
« Reply #25 on: April 03, 2019, 05:54:43 PM »
Where did you get your #38 slow jets from?
Raymond
Raymond
1971 CB500K0 (being rebuilt)
1977 CB550K3 (bases for future 650 cafe racer)
Q plate CB550 in bits
Davelu88
« Reply #26 on: April 03, 2019, 06:37:10 PM »
Got them from Dave Silvers, have to special order them & took about a week to arrive £30 for the 4 of them . part number  991240760380
« Last Edit: April 03, 2019, 06:39:06 PM by Davelu88 »
Re: 550 K1 Carb Help please ( Update )
« Reply #27 on: April 03, 2019, 08:26:43 PM »
Try Sirius in Canada
« Reply #28 on: April 03, 2019, 08:54:30 PM »
« Reply #29 on: April 03, 2019, 08:54:35 PM »
Sounds like a positive step towards optimum.
Longer running and more through heat range may see the plugs a bit better colour as it's used more.
Maybe it'll respond to airscrew tweak if not.
