Author Topic: 3d print files?  (Read 9413 times)
Re: 3d print files?
« Reply #15 on: April 18, 2019, 02:12:33 PM »
Sorry chaps, not going to be able to get this knob off without the risk of breaking something. It is locktited on and I'm concerned that if i try forcefully to remove it, it's gonna get broken, that's if i could even get the screw out. I can still take photos / measurements with it in situ but I'm not sure if that will help much. Let me know if you want me to do that though.
Re: 3d print files?
« Reply #16 on: April 18, 2019, 08:32:21 PM »
Julie, if you can take measurements and photo’s of the exterior and if sprocket can measure and photograph the part that it fits onto, then we can still have a go at producing a CAD model.
Re: 3d print files?
« Reply #17 on: April 18, 2019, 09:15:18 PM »
Ok 👍
Re: 3d print files?
« Reply #18 on: April 19, 2019, 04:55:57 PM »
[ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Re: 3d print files?
« Reply #19 on: April 19, 2019, 04:57:24 PM »
Re: 3d print files?
« Reply #20 on: April 19, 2019, 08:09:17 PM »
That should be good enough Julie. The hole on the other side can be drilled to suit, if I just model up a solid piece that should be ok 👍
Re: 3d print files?
« Reply #21 on: April 19, 2019, 08:11:43 PM »
Sprocket, if you pm me your email address I will send you an stl file on Tuesday when i get back to work... you can then load it straight into your 3D printer.
Offline Sprocket
Re: 3d print files?
« Reply #22 on: April 20, 2019, 09:13:13 AM »
Awesome, thank you very much! Will pm you :)
Offline Sprocket
Re: 3d print files?
« Reply #23 on: April 26, 2019, 09:11:07 AM »
I have a button! Very pleased with this, thank you so much!
I will need to excavate the back of it to take the metal slot, but that's pretty straightforward with a small drill bit.
I imagine loads of people will be after this STL file now...
Re: 3d print files?
« Reply #24 on: April 26, 2019, 09:17:10 AM »
Great work....well done
If I knew what a STL file was, yes, I would probably want one 😀😀😀
« Last Edit: April 26, 2019, 09:18:58 AM by Nurse Julie »
Re: 3d print files?
« Reply #25 on: April 26, 2019, 01:03:30 PM »
Nice one, although the print resolution looks a bit on the low side, do you have your own 3D printer? I printed one out myself the other day here at work just to test the stl, it was a bit smoother than the one on the photo. I could have posted it to you but we only have white plastic...
Offline Sprocket
Re: 3d print files?
« Reply #26 on: April 26, 2019, 01:45:02 PM »
I'm pretty sure the camera is showing it up a bit. I don't have a printer, but a guy in another one of our offices does. I can't tell you what the printer is or what filament it's using - but I'm pretty happy with it so far! I might need a couple more done, so I'll investigate what the resolution is at that point.
Re: 3d print files?
« Reply #27 on: April 26, 2019, 05:41:35 PM »
We have several printers but the best resolution comes with the finest filament...if i can find a bit of black filament i will print you a few....
Offline smoothoperator
Re: 3d print files?
« Reply #28 on: October 27, 2020, 06:26:21 PM »
Did anyone manage to produce any of these switches in black? I am the proud, new member of the missing horn button club.
Steve
2017 Triumph Bonneville T100
Offline allankelly1
Re: 3d print files?
« Reply #29 on: October 27, 2020, 07:08:12 PM »
Hi all
Sorry for the hijack
Just wondering what material were they originally printed in
I am running some ABS on my home printers and for abs one trick is to use an acetone fume chamber to smooth out the lines
Another good material is ASAx that I am printing yam horn covers in (and battery straps in at the moment)
And for the horn cover after a “soak” in my chamber and paint look Bob on
Fresh print in ASAx
After paint
