Author Topic: Rotor removal tool  (Read 8220 times)
Offline heliwilly
Rotor removal tool
« on: May 10, 2019, 07:29:17 AM »
Hi,
I'm trying to find the correct size of thread for a 77 CB400 rotor puller. Apparently the 16mm for the CB550 doesn't fit. Thanks Bill W.
Offline Sprocket
Re: Rotor removal tool
« Reply #1 on: May 10, 2019, 08:36:59 AM »
I was considering this the other day actually. I have a crank with one still attached, I will be taking it to my local hardware supplier tomorrow to ask them to try a bunch of screws in, when I get the right one I'll let you know.
You just grease it up and wind it in, right, same as a bicycle crank extraction?
Offline heliwilly
« Reply #2 on: May 10, 2019, 09:15:55 AM »
That's the problem. If you look on the internet it gives various sizes, 16mm 18mm and 20 mm. Short of buying them all, how can I find the correct one for my brothers 1977 CB400,
Does anyone have the correct answer? Thanks Bill.
« Reply #3 on: May 10, 2019, 09:30:44 AM »
18mm x 1.5 pitch
Offline matthewmosse
« Reply #4 on: May 10, 2019, 09:31:12 AM »
Might be an idea to buy a cheap vernier caliper and set of thread gauges. I find mine invaluable, so much so I now have more than 1 set of each. Often a set of thread gauges is included in a tap and die set. Really useful on matric machinery and pretty well essential if you get anything British and old or Ammerican. The joys of a 196s British vehicle, whitworth,  unf, unc, bsp, etc etc.get on those and it's a real headache.
Offline Sprocket
« Reply #5 on: June 03, 2019, 03:36:09 PM »
18mm x 1.5 pitch
This is correct - big bolt - wind in - pops off.
« Reply #6 on: June 04, 2019, 11:37:15 AM »
Agreed. These Hondas have a mix of standard and fine thread pitches so a set of thread gauges is essential. They only cost about £7 from Machinemart.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #7 on: June 04, 2019, 12:16:14 PM »
For the purists, there is a difference between metric and imperial threads, the thread angle is 60degrees for metric, imperial 57degrees
nice bike,nothing in the bank
Offline heliwilly
« Reply #8 on: June 04, 2019, 02:13:37 PM »
I got an 18mm x 1.5 for the CB400 and a 16 x 1.5 VW transporter wheel bolt ( Via Trigger) for the CB550. Bill W.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #9 on: June 04, 2019, 03:37:45 PM »
Sorry to pedantic but as ka-ja says they are different but the Imperial bit is even more confusing BSF (fine) and BSW (Whitworth) are actually 55 degree included angle not 57.  But BA Threads often found on brass elec fittings are 47 1/2 degrees and have a metric based pitch system.  UNF and UNC are 60 degree thread angle and their spanners are related to the distance across the flats rather than bolt diameter.  No bloody wonder people use bolts in the wrong places and spanners which ‘nearly’ fit.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline bucksfizz
  • 1973 CB750 Four K3
« Reply #11 on: June 04, 2019, 07:33:56 PM »
From memory:
BA used a 47.5° thread angle, Whitworth 55°, and Unified (UNF, UNC, etc.) 60°.
I have a few British clunkers, so I have to fight with these thread forms all the time.
I'll get my coat...
« Reply #12 on: June 05, 2019, 03:21:07 AM »
And i used to pee the plant apprenticles off when they came and asked for a 10mm bolt meaning a 10mm spanner size and i gave them a real 10mm bolt!!!!
Offline ka-ja
  • ken
  • yoshi 460
« Reply #13 on: June 05, 2019, 09:22:51 AM »
Or send an apprentice to the tool stores for a set of footprints!
« Reply #14 on: June 05, 2019, 10:34:31 AM »
Or a 4 inch hole! 😂
