Author Topic: renewing front bearing  (Read 3467 times)
Offline ricardo
« on: May 29, 2019, 05:33:00 PM »
Hello again.
I'm preparing to replace the front wheel bearings. One of the workshop manuals says pack the bearings AND the hub with grease.
The ones I removed seem to be sealed and filling the hub with grease will take an hour. Also there was no grease in the hub when I took it apart.
Ricardo
Offline ka-ja
  • ken
  • yoshi 460
Re: renewing front bearing
« Reply #1 on: May 29, 2019, 07:37:17 PM »
I used to remove the inward facing seal on wheel bearings and 1/2 pack the centre section with grease, double sided seals on bearings can mean they are only oiled
nice bike,nothing in the bank
« Reply #2 on: May 29, 2019, 07:53:15 PM »
Just use good quality bearings NTN 6302 2RS  ;)
Offline ricardo
« Reply #3 on: May 30, 2019, 09:37:47 AM »
thanks bikers
Offline gtmdriver
« Reply #4 on: June 08, 2019, 10:52:53 AM »
If you use aa good quality double sealed bearing you can just fit them as they are and leave the hub cavity dry.
Offline ricardo
« Reply #5 on: June 11, 2019, 08:34:15 PM »
ok
