Author Topic: Bits needed for a rebuild  (Read 3744 times)
Offline Skunkmiester
« on: December 11, 2008, 07:13:47 PM »
Hi there I have just started stripping my 73 CB750 Seeley replica.
I have been looking around and have found most parts online. However I have a couple that I have drawn a blank on. If anyone knows where I can get them please can you let me know?
Bits needed.
- Finned generator cover plate
- Churchgate fairing screen
- The best rear sets to use in conjunction with the original 4 into 4 pipes (not shown in these pics).
Also I would like some advice on getting the aluminium fuel tank repaired. It needs a couple of dents knocking out and also some tarmac gouges sorting out so I need a decent tank repairer who can weld aluminium. Any advice would be great please?
I have started polishing up one of the carbs and it is lokking pretty good, however would soaking them in coka cola speed up the process? Or even Cilit Bang? Then spraying them with Carb cleaner. I have phoned around but it seems that Yamaha Carb Cleaner is no longer stocked.
Thank you in advance.
« Last Edit: December 11, 2008, 07:15:23 PM by Skunkmiester »
