Author Topic: HONDA CB VOLTAGE REGULATOR TEST ETC  (Read 7300 times)
« on: July 09, 2019, 10:56:10 AM »
I was rummaging around on Tinternet for something totally different and found this which may be of use if you are having charging probs. I will also post it in Anoraks Corner.
http://blacksquaremotorcycle.com/tag/honda-cb-voltage-regulator-test/
« Last Edit: July 09, 2019, 11:02:06 AM by Nurse Julie »
Re: HONDA CB VOLTAGE REGULATOR TEST ETC
« Reply #1 on: July 09, 2019, 11:11:04 AM »
Just a note to anyone who is not familiar with Multi meters in the charging test, when you switch from volts to Amps this reading is taken in series with the battery lead.
 Make sure the meter leads are good for the 7-8 Amps ;)
« Reply #2 on: July 09, 2019, 11:21:08 AM »
I have no doubt you are 100% correct Paul. It's a dark art combined with Witchcraft as far as I'm concerned 😪😪😪😪😪
« Reply #3 on: July 09, 2019, 12:31:11 PM »
 ;D ;Djust says switch in the article  :o
Offline rosco
« Reply #4 on: July 09, 2019, 01:22:32 PM »
Hi Julie Hope this has cured Grahams problem on the 750 brat
« Reply #5 on: July 09, 2019, 01:46:31 PM »
I bloody hope so Ross. I have given up asking him if he has found the problem......he goes a sort of purple colour with steam coming out of his ears  ::) ::) ::). TBH, I think he has sorted it, I have been riding it recently with no issues, so fingers crossed.
Offline rosco
« Reply #6 on: July 09, 2019, 02:06:11 PM »
T ;Dold you the trouble was under the left hand cover??? All that time at night school not wasted then
« Reply #7 on: July 09, 2019, 02:17:38 PM »
Well, he has spent a lot of time under that left hand cover 🤔🤔😀😀😀
« Reply #8 on: July 09, 2019, 05:08:00 PM »
He was uffing n puffing about that one even on his day out at Crich  ;D
« Reply #9 on: July 09, 2019, 05:12:22 PM »
« Reply #10 on: July 10, 2019, 01:31:07 PM »
VERY USEFUL LINK! THANKS FOR SHARING.
Offline Menno
  • www.tanklackieren.de
« Reply #11 on: July 10, 2019, 03:51:46 PM »
you can also simply try this:
https://www.youtube.com/watch?v=xF6WUvqC1Xc
« Reply #12 on: July 10, 2019, 08:39:40 PM »
Or use a clamp meter to check the current.  You don't have to break into the circuit and you won't need heavy duty meter leads.
