Author Topic: Poor Cold Starting  (Read 4346 times)
Offline CBNelly
Poor Cold Starting
« on: July 24, 2019, 10:33:30 PM »
Hi,
Have owned my 400/4 since 1990 and always been a good starter
That was until I totally stripped down the carb assembly!
Now takes ages to get going normally with throttle opened
When started it runs fine
Seems like the choke is not working even though butterflys close and tops lift when apply choke
What should I be looking for on carb set-up?
Carbs currently sat on my work bench and all checks so far have yielded nothing
Neil
Re: Poor Cold Starting
« Reply #1 on: July 24, 2019, 11:18:55 PM »
Why did you strip the carbs, did you have a problem with them?
Offline CBNelly
« Reply #2 on: July 25, 2019, 10:18:24 PM »
No, carb strip was to clean and re-plate some external fittings
Ran fine before strip so I think something on re-assembly not right
« Reply #3 on: July 25, 2019, 11:03:17 PM »
Basics to check...depending on what parts you removed......have you bench synced them and have you adjusted the fast idle adjuster as per the manual?
Offline CBNelly
« Reply #4 on: July 26, 2019, 11:15:14 PM »
Only have a Haynes manual
Is there a copy of a Honda manual on this site?
« Reply #5 on: July 26, 2019, 11:50:45 PM »
Look in Aladdins Cave at top of page. In CB400 section.
Offline CBNelly
« Reply #6 on: July 28, 2019, 05:46:02 AM »
Thanks, I'll set up carbs as per manual and see what happens!
Offline CBNelly
« Reply #7 on: August 18, 2019, 07:27:46 PM »
Well, got my carbs back together after fitting new genuine jets, etc. form Mr Silver!
Have a question regarding set-up of the choke
When open should the choke flaps fully cover the inlet port or is there a particular way of setting them up?
Thanks!
« Reply #8 on: August 18, 2019, 07:36:03 PM »
Thanks!
Yes, fully cover the ports when flaps are closed and all totally horizontal and level when open. Adjust using the adjusters.
Offline CBNelly
« Reply #9 on: August 19, 2019, 10:11:27 PM »
Thanks for response
Also have a question regarding setting up of the slides
Honda manual says should be 0-1mm from top of inlet port when throttle wide open
Not easy to adjust while holding throttle open against the spring, is there a measurement you can take from the bottom of the inlet when the throttle is closed?
I seem to recall someone using 1.5mm drill bits to measure this gap, is this right?
« Reply #10 on: August 19, 2019, 10:19:07 PM »
Bryans explanation is spot on and works perfectly.http://www.sohc.co.uk/index.php/topic,17769.0.html
