Author Topic: Hesitant revs below 3,000 RPM when hot.  (Read 22545 times)
Offline Bradders
Re: Hesitant revs below 3,000 RPM when hot.
« Reply #15 on: August 09, 2019, 06:59:56 PM »
Thanks Northy. I checked my plugs last night and when compared to the photos in the manual looked like might be running rich. So for the price of a new filter I think it will be worth trying.
Offline Chris whit
« Reply #16 on: September 01, 2019, 09:05:15 PM »
Hi , did you manage to sort your problem , i have exactly the same problem , mine is bogging down when trying to set of when warm . The carbs were reconditioned a couple of months ago and all was fine . Started doing this a couple of months after . Stripped and cleaned carbs and slow running jets  again . Seams to be running rich i think . Would using a smaller slow running jet sort the problem or is there anything else that you guys would suggest . Bike runs fine and pulls great with no smoke , done a colour tune and carb balance.
« Reply #17 on: September 01, 2019, 09:13:21 PM »
Don't change jet size, just keep standard ones and play with air / mixture screws. What are the screws set at at present?
Offline Chris whit
« Reply #18 on: September 01, 2019, 09:40:32 PM »
Julie , they are set to 1, 3/4 turns , i have noticed that I don’t have to use much choke to start the bike from cold . I originally bought this set of reconditioned carbs from Gerben . Might try changing plugs and air filter.
« Reply #19 on: September 02, 2019, 08:57:48 AM »
As above,  they would be unusual to need jets away from spec if all is standard.
But running rich is clear to see and feel with no choke starting if ambient temperatures are down.
What length of time has the air filter been in the bike and is it in any way impaired? It's not unknown to get a pattern filter that hasn't got decent flow capacity so inspect carefully to make sure it's OK.
Try taking it out to see if it runs more normally mixture wise just for a test.
Offline Bradders
« Reply #20 on: September 02, 2019, 10:33:59 AM »
Morning. Not had chance to do any of the suggestions as been away on holiday in Canada last couple of weeks, wall to wall Harley’s out there. K2-K6, could I run it without the filter for 20 miles to test or is that too long? The problem only seems to happen when the engine is hot.
« Reply #21 on: September 02, 2019, 10:41:50 AM »
As long as there is no dust storm that should be ok
« Reply #22 on: September 02, 2019, 11:36:59 AM »
Yes as Bryan says, ok to go without filter for that time.
It may be a good idea to use a vacuum cleaner inside the airbox when you take the filter out to remove any extraneous debris before you start it.
Offline Northy
« Reply #23 on: September 02, 2019, 04:47:37 PM »
They should be 2 turns (+/- 1/4 ) so close to standard but I'd screw then out a bit, try 1/4 at a time , so could be a easy fix.
How many is too many bikes ..... when you have no space left.
« Reply #24 on: September 02, 2019, 05:33:04 PM »
Should be 2±½ on a CB400/4, which gives a little more leeway to fettle.I have mine set at....No 1, 2 ½ out, No's 2 & 3, 2 3/8 out and No.4 2 turns out. But every set of carbs will be slightly different.
« Last Edit: September 02, 2019, 05:36:36 PM by Nurse Julie »
Offline Chris whit
« Reply #25 on: September 02, 2019, 09:35:11 PM »
Thanks guys , ill try running it without the filter  . Ive got a new one from DS sitting on the shelf .
Offline ogri211
« Reply #26 on: September 03, 2019, 07:31:25 PM »
Problems when hot could be down to valve clearances have you checked them?
Triumph Rocket3, Suzuki GT 750A, Kawasaki H1B, Honda 400 Four, Triumph Speed Triple
Offline Bradders
« Reply #27 on: September 10, 2019, 04:27:28 PM »
Rode my bike today without the air filter as suggested by Northy and seems to of solved the problem. Will try agaiin tomorrow and if ok will buy a new air filter. Also changed the gauze ( Scourer pad ) as it was a bit mucky. Thanks for the suggestions.
« Last Edit: September 10, 2019, 05:51:11 PM by Bradders »
« Reply #28 on: September 11, 2019, 07:31:04 AM »
Hopefully you'll find it's the same with a new filter installed now.
A friend with a 400 (years ago and new bike) had been riding to work in the rain, sunny on the way home but the bike just wouldn't run or rev at all once warm. Just about made a detour to the supplying dealer, bike chugging along at slow speed, they had a look at it,  opened the seat and took out his waterproof overtrousers,  at which point it ran fine again. Mostly blocked the filter box intake with the trousers  ;D
Let us know how you get on Bradders.
Offline Bradders
« Reply #29 on: September 11, 2019, 07:52:13 AM »
I will K2-K6. Is Dave Silvers the best place to get a new filter from?
