Author Topic: Spring pin location?  (Read 2904 times)
Offline Crispy
« on: August 25, 2019, 05:49:53 PM »
Can anyone identify where this spring pin should fit in 71 K1?  It measures 5*22 mm, I have it labelled as wheel hub but cant see where it would fit in either hub. Looks like I've mislabelled it. I've searched my manual and parts book from front to back but can't find it in those either. :-\
Re: Spring pin location?
« Reply #1 on: August 25, 2019, 05:59:48 PM »
I have never seen one before Mick but Trig may be able to shed some light on it. I will ask him when he gets back in.
« Reply #2 on: August 25, 2019, 06:34:33 PM »
I can only recall one roll pin on a K1 and that holds the kick start spline and that one is too small  ;)
Offline Crispy
« Reply #3 on: August 25, 2019, 06:53:02 PM »
Cheers Graham, that's very reassuring! I know the kick start pin is in, but have no idea where this one has come from. I was beginning to panick!  :-\
Online Bryanj
« Reply #4 on: August 25, 2019, 08:51:30 PM »
I have a vague memory of seeing a master cylinder with a roll pin in vertically between reservoir and lever pivot
Offline Crispy
« Reply #5 on: August 26, 2019, 09:07:48 AM »
Cheers Bryan , Yes, I did think that might be  the location when I looked through the parts manual but it turned out to be for a rubber bush which replaced a cam type fitting on earlier models which apparently adjusted lever distance ?
« Reply #6 on: August 26, 2019, 11:13:34 AM »
Does the 750 have the same right footrest layout as the 400?
There's a roll pin to locate the spring that holds the footrest up when using the kickstart.
Offline Crispy
« Reply #7 on: August 26, 2019, 06:47:35 PM »
Good shout but no they must be different, there's no roll pin in my footrest set up.  :-\
