Author Topic: Rear wheel bearing retainer stuck  (Read 22674 times)
Offline eight0
« on: September 04, 2019, 04:38:12 PM »
Last week I finally got round to sending my wheel hubs off to Hagon to be built with Excel rims and SS spokes.
I left the rear hub assembly whole and asked them to take the bearings out and polish the hubs for me. I just had a call from them to say that they have made a bearing retainer tool, had the hub clamped to a milling machine, applied heat etc etc but cannot get the thing undone.
They have advised me to find a new hub...
I could ask them to send it back to me and try myself but if they can't do it when it's clamped in a milling machine then I am unlikely to be able to do it with just my bench vice.
Anyone got any pearls of wisdom?
Offline Moorey
Re: Rear wheel bearing retainer stuck
« Reply #1 on: September 04, 2019, 04:57:35 PM »
Do you know if they have drilled out the punch marks. If not they are extremely difficult to remove and will destroy the threads.
« Reply #2 on: September 04, 2019, 04:57:45 PM »
It's a left hand thread, just in case they are trying the wrong way.
Offline eight0
« Reply #3 on: September 04, 2019, 04:58:38 PM »
He didn't say, so maybe not. I'll call them and find out.
Offline eight0
« Reply #4 on: September 04, 2019, 04:59:31 PM »
Thanks Julie, He said they happened to have another hub they were doing for another customer and checked they were doing it the right way.
« Reply #5 on: September 04, 2019, 05:01:05 PM »
It should come out then, if as Moorey has said they have drilled the punch marks out.
Offline Moorey
« Reply #6 on: September 04, 2019, 05:05:41 PM »
They do not need to drill all the way through but just remove the bit of distorted thread caused by the punch.
Offline eight0
« Reply #7 on: September 04, 2019, 05:12:10 PM »
Thanks for the help. They aren't answering the phone now so I've sent them an email. Hopefully that's all it is!
I'll report back when I hear more.
For anyone looking a this post in the future, I just found this very clear and useful page. http://blacksquaremotorcycle.com/how-to-drill-out-stakes/
« Last Edit: September 04, 2019, 05:18:53 PM by eight0 »
Offline jon stead
« Reply #8 on: September 04, 2019, 10:10:02 PM »
I couldn’t get mine out. I ended up drilling it and splitting it. The replacement one screwed back in without any issues.
« Reply #9 on: September 04, 2019, 11:41:06 PM »
That's what I had to do on the last one I did
Sent from my Moto G (5) using Tapatalk
« Reply #10 on: September 05, 2019, 09:21:30 AM »
They are a total sod to remove .. I had to make these up to get mine out. I made the big mistake of stripping the wheel rim before removing the retainer so I had to make a hub holding tool by welding the old sprocket to a piece of angle iron.. I am not 100% sure but mine may have been Loctited too, in addition to staking, by a PO as the bearing wasn't the original one.
« Last Edit: September 05, 2019, 09:23:43 AM by AshimotoK0 »
Offline eight0
« Reply #11 on: September 05, 2019, 10:05:10 AM »
I've just spoken to them again. They had drilled out the stakes, apparently the guys in the engineering shop spent a couple of hours trying to get it out.
They said they would try again and I said if they could drill it out then do that. There's a NOS retainer on ebay at the moment for 50 (seems steep but cheaper than a new hub)
Offline Moorey
« Reply #12 on: September 05, 2019, 10:19:19 AM »
Personally I find it far easier to fasten the removing tool in the vice and put the wheel on top and then use the wheel to undo the retainers and  never had a problem doing it that way.
Offline eight0
« Reply #13 on: September 05, 2019, 10:31:10 AM »
Unfortunately I had already removed the spokes and hub
« Reply #14 on: September 05, 2019, 10:52:43 AM »
Here's the tool I made.
