Author Topic: 400/4 Exhaust Fitting Info needed  (Read 6777 times)
Offline THUNDERDOWNUNDER
« on: October 24, 2019, 11:12:42 PM »
I have inherited a set of replacement Pipes and collector box (Silvers ) for 400/4 . All brand new but no instructions . The pipes are marked 1 2 3 4 . My question is which way round do they fit the collector box ? I see on one side of said box has a fitting for a retaining bolt ( I don’t have ) The other three slots have nothing to hold pipes . So looks like press fit ! Any help welcomed.
Re: 400/4 Exhaust Fitting Info needed
« Reply #1 on: October 25, 2019, 12:03:43 AM »
I've got the same set on mine. The clamp on the collector is on the underside,  this puts the silencer outlet to the outer righthand side of the bike. The pipes are obvious then. The longest pipe goes from furthest cylinder to corresponding collector inlet and so on until shortest pipe goes from righthand cylinder to the righthand collector inlet. I used some exhaust paste on the push in pipes to make sure they sealed.
See Gallery photo of my CB400F Cafe racer 2.
Ps. It's a bastard to fit!
I just remembered,  Fit the silencer to collector box first, helps to line up the mounting points.
« Last Edit: October 25, 2019, 12:07:10 AM by taysidedragon »
« Reply #2 on: October 25, 2019, 01:52:38 AM »
Thanks taysidedragon , invaluable help there . Yes I was thinking of useing a bit of heat on the collector box to help get the pipes in as they seem reluctant to fit . Did you push them to a stop or is it see how you go ? Hope you didn’t get any leaks .i wonder if the clamps (Silvers )are selling would help seal it ? Rob .
« Reply #3 on: October 25, 2019, 08:15:50 AM »
Clamps won't do anything as there is no slots on the other three inlets on the collector.
« Reply #4 on: October 25, 2019, 08:36:44 AM »
Had a go at fitting down pipes to collector box . No Luck  . If they are this hard to fit they aren’t going to leak that’s for sure !
« Reply #5 on: October 25, 2019, 10:00:16 AM »
Mine slid in nicely with a good close fit. I pushed them in as far as they would go but had to ease a couple back out a little to adjust the fit to the head. No leaks.
« Reply #6 on: October 25, 2019, 11:24:05 AM »
Thanks these are. going to be a challenge but if they can put a man on the moon I can sort this out !
« Reply #7 on: October 25, 2019, 11:43:31 AM »
As Tayside said in an earlier reply, they are an absolute pig to fit and you will get angry >:(!  You will think they are bent or twisted and not to spec but they are! Mine kept hitting the sump pan and it took forever to get enough clearance.  Don't do anything up tight (including the exhaust collars at the head) until you have everything aligned and then go around tightening the clamps etc in stages checking clearances all the time. A bike lift makes things a lot easier, I spent most of the day on the floor!
« Reply #8 on: October 25, 2019, 10:36:18 PM »
Thanks Laverda , I am having trouble just getting the pipes to fit into the collector box so if it’s going to be a bastard with the rest of the set up I may have to set aside a weekend to have a go . You would think as the pipes are all numberd it would be a breeze so thanks for the warnings . In God we trust . All others pay cash .
« Reply #9 on: October 27, 2019, 07:06:40 AM »
Well it’s a nice day here 35 degrees in the shade . Left the Collector box in the sun for a few hours and had to wear gloves to pick it up . Put cold down pipe to collector box just managed to get it started a few mill and that was it . Maybe I need a hotter day ?
« Reply #10 on: October 27, 2019, 09:58:31 AM »
That sounds too tight. Are the pipes out of round and causing the binding?
If not you may need to remove a bit of metal to ease the fit. A gentle dremel round the inside of the collector pipes?
« Reply #11 on: October 27, 2019, 11:44:44 AM »
Funny you should say that . I will try a socket on it tomorrow for roundness . If all ok will get the dremel out or lots of elbow grease with the emery paper ! Thanks for all the input guys !
« Reply #12 on: October 27, 2019, 11:27:32 PM »
Just another thought on this . Why is there only one retaining clamp on the collector box ?
« Reply #13 on: October 28, 2019, 11:03:59 AM »
Good question. I guess it's cheaper to manufacture and when it's all assembled just one is enough, the others can't move.
« Reply #14 on: November 03, 2019, 06:48:35 AM »
Problem fixed .slight lip on collector box inlets . Looked like build op of Crome platting . Filed it flush . Just have to assemble them now Agh !
