Author Topic: CB550 carbs  (Read 4514 times)
Offline Moleskins
CB550 carbs
« on: October 26, 2019, 03:18:00 PM »
Sorry about this, I’ve gone through various posts and can’t find any answers.
I’ve got 022A carbs on my CB550K0
I’ve stripped them cleaned and replaced the O rings but not jets, just cleaned those. They’re stock 100 and 38
I’ve replaced a dodgy rubber which was leaking
I’ve had gauges to set the vacuum
I’ve static and strobed the timing
I’ve ditched the pod filters and got a used airbox, filter is dirty though
I’ve got it to run but it runs very rich, the air screws are out about 3 1/2 turns!!
Nothing seems to make a jot of difference. Needles have been up and down, currently in the middle.
I’ve read there are fine holes in the carb body which block, I did blat carb cleaner down the ones I could see. Had this problem on another bike which took 3 goes to get them cleared finally using a guitar string.
So any suggestions and how do I get the bloody carbs off now it’s connected to the air box??
Ppl
Re: CB550 carbs
« Reply #1 on: October 26, 2019, 04:16:03 PM »
You probably need to change the filter as if it looks dirty it'll be having more of an effect than appreciated.
It's one of these non-linear scenarios as it'll cope with quite a lot of dust before getting the flow exponentially affected.  Difficult to judge without swapping to test it, but run it with filter out just as reality check first.
Offline Moleskins
Re: CB550 carbs
« Reply #2 on: October 26, 2019, 08:12:48 PM »
What would be the consequence of having too much fuel in the float bowl?
Not enough to cause it to overflow but too much?
I’ve set floats at 22mm.
Re: CB550 carbs
« Reply #3 on: October 26, 2019, 08:31:57 PM »
That would bias it toward richer mixture,  but its a very subtle change and more apparent right at the lowest revs.  Probably unnoticeable at higher rpm.
With the jets you've stated,  it's unlikely to be able to run rich as they control maximum flow.  Leaving a reduction of air to give you rich mixture the most probable cause.  Without confirming the airfilter you may go round in circles.
To check the primary circuits,  with it running and warmed, you should hear a response as you wind each one of the screws in and out individually like a small throttle for that cylinder.  If no response is present it would indicate that circuit was impaired. But again that response is dependent on having normal airflow in the first instance.
Offline Moleskins
Re: CB550 carbs
« Reply #4 on: October 26, 2019, 08:43:05 PM »
I don’t notice any change as I alter the air screws.
Definitely runs richer set anything less than 3 1/2 turns out. It was on pod filters so no shortage of air.
Re: CB550 carbs
« Reply #5 on: October 26, 2019, 10:12:03 PM »
There is a spider in the slow running jet and the main jet if, you have pocked anything down the hole, the spider is destroyed and air mix disrupted. The clip should be second down on the needle.
Offline Moleskins
Re: CB550 carbs
« Reply #6 on: October 27, 2019, 08:26:46 PM »
Thank you for that Trigger. I have no idea what’s been poked down holes over the last 45 years, this makes it interesting though doesn’t it.
Offline paulbaker1954
Re: CB550 carbs
« Reply #7 on: October 29, 2019, 08:37:39 AM »
Hi
Sounds like you have a blockage in the idle fuel/air circuits. I had this issue until eventually I ultrasonically cleaned the carbs and cleared them all out with compressed air.
If you want to read about how and where these very fine ilot circuits go have a butchers at the post I did a while back
http://www.sohc.co.uk/index.php/topic,16351.msg138049.html#msg138049
As to getting the carbs off I have found that the best method is to push the airbox rubbers back in to the airbox as far as you can (you can even push them right through if you want, just a bit harder to get them back on). This will give you enough wiggle clearance to get them off.
I have had many gos at this over the years and I can have the carbs off in around 30 mins now !!!
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Moleskins
Re: CB550 carbs
« Reply #8 on: October 31, 2019, 10:52:22 PM »
Paulbaker1954
Thank you, I’ve finished the ultrasonic clean today. I gave up and bought one.
During the rebuilding I kept thinking’this doesn’t make sense, it’s running rich, I’m cleaning fuel ways out’.
Anyway I fed a bit of guitar string into the slow jet. This measured 17 thou. From memory that equals .43mm the jet is marked 38 so I think there lies the problem.
Online deltarider
Re: CB550 carbs
« Reply #9 on: November 01, 2019, 08:23:52 AM »
Why did you use a steel string that is harder than the jet's brass? Anyway, that's probably what the PO did...
Offline Moleskins
Re: CB550 carbs
« Reply #10 on: November 03, 2019, 06:05:56 PM »
I understand why you’d say that. However I can’t imagine it would be possible to make a bendy guitar string go through a hole which was smaller than it.
Anyhow, I’ve replaced the slow idle jets with 38’s and balanced the carbs. It’s much improved but coughs a bit going up the road, lacking power. Once revs are at about 3500 it’s much better. That’d be Main jet though at that stage.
The exhaust still indicates running rich, any attempt to put a filter in the airbox makes that worse.
I’m contemplating dropping the needle to lean that off, currently needles are on the middle setting.
Vacuum gauges are on about 8 inches which if I’ve converted correctly equates to the book 16-24 cm HG
Re: CB550 carbs
« Reply #11 on: November 03, 2019, 06:14:24 PM »
There is a lot of overlap of jets when going from idle jets to main jets, so at 3500 rpm it could be either jet. Nigel (K2-K6) posted a brilliant graph showing the overlap but i can't find it again now. Also, as long as the vacuum gauges are showing parity, it doesn't matter what the reading is within reason.
Offline jon stead
Re: CB550 carbs
« Reply #12 on: November 03, 2019, 06:51:05 PM »
If you’ve measured 8 inches of water, then that’s about 1.5 cm of mercury. 16cm of mercury is about 85 inches of water !
Re: CB550 carbs
« Reply #13 on: November 05, 2019, 08:36:27 AM »
I can't find that either Julie even though I thought I had a copy tucked away somewhere here.
For your current jetting though,  as you plan,  put the needles down a notch to try it and see what you get.  Obviously you've got progress with the new idle jets and it's just moving something else now to bring in other sections of mixture to where you want it.
If you've got room to bring the idle screws out another 1/4 turn it's worth trying that.  It should delay the point at where the idle jet gets to full flow at it's 38 capacity and be matched with the throttle slide being a little higher when it occurs.  That and dropping the needle a notch combined will effectively lean out the middle range throttle opening and may get you into range.
Re: CB550 carbs
« Reply #14 on: November 05, 2019, 08:41:20 AM »
An additional point to consider,  the airbox on these can have different configurations I believe from other's experience on here.  Deltarider?  They have a different air entrance to make some market models quiter I think, these are paired with smaller main jets, from memory, and run at slightly smaller mains it seems.
Someone with that knowledge may be able to help here in identifying the parts you have.
