Author Topic: 750a hondamatic  (Read 3498 times)
Offline bigbikelittlebloke
750a hondamatic
« on: March 05, 2009, 09:34:11 AM »
Hi, has anyone any ideas where I can get a front sprocket or kit for  my 750a. the honda part is no longer  available, I`ve tried David Silver, CMSL etc, all with no joy. I`ve tried cross referencing the honda no with various firms with no success. thanks Rich
Re: 750a hondamatic
« Reply #1 on: March 05, 2009, 02:16:27 PM »
Having done a small amount of resurch for you i have discovered the following
The front sprocket retaining plate is the same as 450 twin, 500/550 four and early 750 four so a sprocket for those will fit CAREFULL as these use 530 chain.
The rear sprocket carrier is the same as the 750 K7/8 These used a 630 chain but i know sprockets are made for 530.
You can therefore get sprockets that will fit but probably not in 15/42 teeth ratio and in 530 not 630 chain. If you use a high strength "O" ring chain this should not be a problem
