Author Topic: piston ring compressor  (Read 7780 times)
MIKE550/4
« on: March 23, 2009, 01:40:47 PM »
what tool do you guys use when barrels getting put back on
ie pressing the rings to slide the barrels down, any links to place where i could purchase ?
one in the manual looks very honda mechanic only ,
Offline JonnyB
    • BatchScan
Re: piston ring compressor
« Reply #1 on: March 23, 2009, 01:48:34 PM »
I've never used one, the lip at the base of the barrels (on 750 anyway) is large enough to push the rings in as you slide the barrels over the pistons. I've always used loads and loads of clean engine oil during reassembly, and with the outer pistons raise slid the barrels downwards. You may need to pinch the rings as you go, but this can be done by hand
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
John
https://batchscan.co.uk/
« Reply #2 on: March 23, 2009, 04:29:13 PM »
Same with the 500/550, the lip at the base of the barrels is enough.
Just don't force it and use loads of engine oil.
John and I must have learned in the same "engine rebuild" class!
MIKE550/4
« Reply #3 on: March 23, 2009, 04:32:42 PM »
right interesting no need to for compressor then.....
when you say use plenty of engine oil , is that round the piston , down the barrel, or both , anything else to watch out for
Offline JonnyB
    • BatchScan
« Reply #4 on: March 23, 2009, 04:40:38 PM »
Rule of thumb -  when rebuilding and engine, you can never use too much oil during a rebuild, if it's metal-on-metal -  lube it
John
« Reply #5 on: March 23, 2009, 04:46:03 PM »
Yea!
Pour it everywhere!
Offline matthewmosse
« Reply #6 on: March 23, 2009, 07:27:53 PM »
once you've added more oil, put a bit more on there, I also use fingernails to feed the pistons back into the barrells, I try to feed in the middle pistons first. I have a draper piston ring compressor but it's pretty much useless for bikes appart from my 1000cc bmw as with most diy mechanics tools it's intended for cars.........
Offline florence
« Reply #7 on: March 24, 2009, 08:51:45 AM »
Make sure you have the ring gaps in different places, say 12 o'clock, 4 o'clock 8 o'clock.......
Start with the middle cylinders, smear the cylinder wall with lots of oil.  Once the piston is introduced into the lip the rings should guide in by themselves.  Use your fingers to squeeze them in but don't force the piston too hard.  Gently rocking the piston on the gudgeon pin axis helps too.  Take your time and you should find it easier than you might think.
