Author Topic: cafe racer project  (Read 5130 times)
Offline bikerburke
cafe racer project
« on: March 24, 2009, 11:35:04 PM »
hi all,this is my first post since joining so i hope i get it right.as i said when i joined i am building a cafe racer based on a 500/4 1973 model.I have include a few shots of before and how far I've got so far.I did say i was trying to build it on a budget but that went out the window when I started spending at DS SPARES .good old EBAY supplied the tank ,fairing and a seat for
« Last Edit: March 25, 2009, 06:14:03 PM by bikerburke »
1972/3 cb500 ,shed to cafe racer in10 easy steps i hope :)
Re: cafe racer project
« Reply #1 on: March 25, 2009, 04:06:52 AM »
750 has bigger discs, if you want to use the 500 size get the 550 lowers but all will fit on the legs.
Original relay was 3 pin but the Yanks use a 2 pin and yes all bulbs have to be correct size, working and eathed properly---usualy needs the engine running to charge battery to get a regular flash rate as well
« Reply #2 on: March 25, 2009, 07:02:11 AM »
Looks good Mick.
Did you do any engine work?
Where are you?
2022 Tiger Sport 660
Offline matthewmosse
« Reply #3 on: March 25, 2009, 09:24:21 AM »
looking good there. I'm inpressed. Re, dual disking it, I'll check in my spares to verify this, but I think the cb550 forks are marginally longer, one ir 2 inches, you do sometimes come accross cb500 forks with the lugs for twin disking on, I got a set off ebay a year or 2 back but they don't come up often, I've heard mixed reports on the effectiveness of dual disking, quite a few recon it's not really cost effective, I've only done a few miles on a 550 with it done but couldn't spot the difference in braking efficiency, the single disk will if working right lock the front wheel even with a sidecar on the bike, futher upgrades mostly mean swapping the whole front end for more modern kit like the cb400N superdream which slots streight in using all standard bearings etc.
Offline bikerburke
« Reply #4 on: March 25, 2009, 06:11:25 PM »
thanks for your help/info guys.new indicators on the way and a caliper unit and disc also on the way.re forks ive remeasured all dimensions again on the 750 forks (perhaps there not 750) and they match exactly to the ones i have on already as i said the only difference is in the stanchions and damper so it may be a case of fit and try.ive incuded a couple of pics of the 750? and my own forks.I have a a couple of other issues i could have advice on should i start a new topic for each one.  PS steved cb500 i live near wrexham .north wales
« Last Edit: March 25, 2009, 06:13:32 PM by bikerburke »
