Author Topic: 350 / 400 Float Bowl O rings  (Read 5042 times)
Offline Moorey
« on: January 08, 2020, 08:45:25 PM »
Anyone know the o-ring size for the float bowls on the 350/400.  Ta.
« Last Edit: January 12, 2020, 05:50:40 PM by Moorey »
Offline Moorey
Re: 350 / 400 Float Bowl O rings
« Reply #1 on: January 12, 2020, 05:51:17 PM »
Bump.
« Reply #2 on: January 12, 2020, 05:54:51 PM »
No idea Chris.... I always buy mine direct from Gerben.
Offline awrawr
« Reply #3 on: January 12, 2020, 10:10:39 PM »
I have some in a packet with a label on it stating the size..... when I can find it. Watch this space...
Offline Moorey
« Reply #4 on: January 12, 2020, 10:19:24 PM »
Cheers and welcome to the forum. :)
Offline H2Eric
« Reply #5 on: January 13, 2020, 11:30:57 AM »
I always use the shaped ones, which can usually be found on flea-bay.
Eric
Offline awrawr
« Reply #6 on: January 13, 2020, 08:11:30 PM »
Thank you. I've been on the US site for a while 'cos I couldn't find this one!
The bowl takes a 63mm x 2.0mm. A 2.5mm will fit but I think they're a touch too fat, stopping the faces from mating properly and risking warping the joint.
Offline Moorey
« Reply #7 on: January 13, 2020, 10:38:22 PM »
Thank you.
