Author Topic: Bottom hanger bolt.  (Read 2316 times)
Offline brodsord
Bottom hanger bolt.
« on: January 20, 2020, 07:25:43 PM »
Hi all,
Can anyone tell me if the bottom engine hanger bolt for a CB750 f2 is longer than the same bolt for a CB750 k5 ?
Also is there difference in the long front engine hanger bolt between those two models?
Many thanks
Offline Erny
  • CB750K7 CB550K1
Re: Bottom hanger bolt.
« Reply #1 on: January 20, 2020, 07:30:57 PM »
I do not have personal experience, but I would look at spare parts catalogue to check first. Shall be clearly visible there
Odoslané z SM-G930F pomocou Tapatalku
CB750K7 US model (1977)
CB550K1 US model (1975)
« Reply #2 on: January 20, 2020, 08:14:01 PM »
I have 750K bolts, if you would like the length. The front lower is 90152300010 for the K and F1 and F2  ;)
Offline brodsord
« Reply #3 on: January 20, 2020, 08:44:32 PM »
Thanks very much Trigger.
I’m doing a build which is a f2 frame and a k5 engine.
The rear bottom bolt seems to be to short by the time it goes through the frame then out the aluminium peg mounting blocks.
I haven’t got enough thread to mount the forward foot rests, I got the bike as just a rolling frame and engine it had nothing else so I’ve been slowly sourcing parts and putting here back together and the front mount is just a bit of m10 threaded rod, do you have a spare rear lower and the front clutch side bolt for sale at all?
Offline brodsord
« Reply #4 on: January 20, 2020, 08:49:29 PM »
Thanks Erny
« Reply #5 on: January 20, 2020, 08:49:41 PM »
The bottom rear is unique to the 750F2, none of the other SOHC 750's use those alloy footrest brackets. Try D.K. spares or similar for one.
Offline brodsord
« Reply #6 on: January 20, 2020, 08:51:30 PM »
Thanks pal, I think the bolt that’s there must be of an earlier model, the bike is a bit mix and match
« Reply #7 on: January 20, 2020, 09:47:06 PM »
If you contact the Nurse, she will check the stock. I have seen a 750K lower front and a rear hanger bolt about  ;)
Offline brodsord
« Reply #8 on: January 20, 2020, 10:18:16 PM »
Will do Trigger.
Gray
