Author Topic: engine rebuild  (Read 9058 times)
MIKE550/4
engine rebuild
« on: April 02, 2009, 10:32:00 AM »
hi all
right after hours of tedious cleaning, scraping , priming, painting lacquering etc finally ready to rebuild this engine, have a compresor on way to replace stem seals... so engine rebuild
totally new to this and firstly must thank all on here been a great help ( extra thanks to bryan j , anything he does not know about these bikes?)
ok all surfaces to be mirror clean, can you guys give me tips on rebuild, few things i am confused with ie order to rebuild, scared about missing a gasket
confused about cylinder sleeves at base do these sit inside base gasket or around the barrell and pressed down
base and head gasket look the same? is base more paper?
tach drive gasket ... please explain in lamens terms
also position of pistons .. is there a set position
have included some pics ( apologies a bit blurry on a couple)
maybe usefull to some to show what you now get
cheers again  mike
ps 2 pics showing main gasket , but you also get the following
p91204286003  KICKSTART SHAFT
p01205283015  SPROCKET SEAL
p91202426003  NEUTRAL SWITCH
91256-096-651 TACH DRIVE
p91201323005  CRANKSHAFT GENERATOR END
p91201300003 CRANKSHAFT POINTS END
91259vm0000  CLUTCH OPERATING ARM
9120737h000  BLANKING PLUG
p91202kfl841  GEARCHANGE SHAFT
missing is the pucks ( as per bryan )6 x  91318-300-013
Re: engine rebuild
« Reply #1 on: April 02, 2009, 07:33:18 PM »
Got any better pics Mike? I've tried blowing them up to [width=600] which is best for this forum but they are too pixelated.
MIKE550/4
Re: engine rebuild
« Reply #2 on: April 02, 2009, 09:53:28 PM »
heres a link to full sized photos if that helps steve
« Last Edit: April 03, 2009, 07:40:54 AM by SteveD CB500F »
Offline matthewmosse
Re: engine rebuild
« Reply #3 on: April 02, 2009, 11:28:26 PM »
Head gaskett has 2 6 mil bolt holes sticking out in front of and rear of camchain tunnels and metal rings round piston holes plus is far heavyer duty to base gasketts, there are as I recall 4 X O rings lodged around the bottom of the cylinder liners in a groove between the liners and alloy casting. There is a seal inside of the tacko drive (inserty thingy) and an O ring on the outside.
Re: engine rebuild
« Reply #4 on: April 03, 2009, 07:41:39 AM »
If you paste the "IMG Code" from Photobucket into your post, you'll get the pictures direct.
I've edited your post to show.
MIKE550/4
Re: engine rebuild
« Reply #5 on: April 03, 2009, 04:45:10 PM »
cheers steve
would this be worth building it up back in the frame
ie put bottom end back in frame first ?
Re: engine rebuild
« Reply #6 on: April 03, 2009, 10:18:45 PM »
I don't see why not. You can do a complete top end strip on the 500/550 with the engine in the frame as there is enough clearance for the cylinder head below the main frame tube (unlike the 750).
Re: engine rebuild
« Reply #7 on: April 04, 2009, 09:14:00 AM »
Also means its not as heavy and easier to get into the frame without scratching the paint!
MIKE550/4
Re: engine rebuild
« Reply #8 on: April 04, 2009, 08:35:57 PM »
ok engine is in , did it lay on side method and put frame onto it, not too bad
anyway question straight away,been looking at microfiche and need to check something which looks important, i seem to be missing whats called a dowel pin
2 sit on the barrels, not sure if diagnol or same side but sure i should have 2
if i am missing this are they still available, or anyone got one
think its part no 94301-12180 or 94301-12160
cheers all
mike
getting there slowly  ;)
« Last Edit: April 05, 2009, 06:21:22 PM by MIKE550/4 »
Re: engine rebuild
« Reply #9 on: April 05, 2009, 04:32:47 PM »
Do you mean cylinder to head or cylinder to crankcase?
MIKE550/4
Re: engine rebuild
« Reply #10 on: April 05, 2009, 06:42:35 PM »
cylinder to head ,have none to the crankcase  :-\
MIKE550/4
Re: engine rebuild
« Reply #11 on: April 11, 2009, 09:38:52 AM »
hi all
cannot get the cam to sit correctly,feeding it in from the right , seems the cam chain keps getting wedged, any tips
2 questions on fitting the cam cover, realise i have to set cam and mark in timing window my book has big oily print on it and not very clear, is it notch level with cylinder head joint face? and line in between t and f markings in the middle of window at bottom?
also noticed fitting cam cover on the cylinder head can cause problems ( bent valves?) so whats the process to avoid this
cheers
mike
« Last Edit: April 11, 2009, 06:08:38 PM by MIKE550/4 »
Re: engine rebuild
« Reply #12 on: April 12, 2009, 10:40:36 AM »
Mike use this link:-
http://forums.sohc4.net/index.php?topic=369.msg57914#msg57914
And i will try and call tonight
MIKE550/4
Re: engine rebuild
« Reply #13 on: April 12, 2009, 10:15:01 PM »
i am doing some thing wrong tried all afternoon with no joy  >:(, seems realy tight, can get one side on, but will not go over the top, gave up now before i break the chain, will await your input  :)
