Author Topic: rear wheel  (Read 1948 times)
Offline Philh550
rear wheel
« on: January 31, 2020, 11:04:46 AM »
Hi all
has anyone else had trouble fitting the rear wheel on their 550 F1 ? mine is really tight to fit. I have put in new wheel bearings and double checked they are seated all the way in but still need a pry bar to get the last spacer and chain adjuster to fit.
Thanks Phil
Re: rear wheel
« Reply #1 on: January 31, 2020, 08:18:58 PM »
Was it ok before you took it out?
Offline Philh550
Re: rear wheel
« Reply #2 on: January 31, 2020, 08:46:42 PM »
Bought the bike dissembled. Its what you call a project !
Re: rear wheel
« Reply #3 on: January 31, 2020, 10:18:58 PM »
In that case could be wrong brake plate or spacers they do vary
Re: rear wheel
« Reply #4 on: January 31, 2020, 11:10:31 PM »
Or hub or swinging arm ;)
The spacer on the brake plate side is 38mm
« Last Edit: January 31, 2020, 11:16:00 PM by Trigger »
Re: rear wheel
« Reply #5 on: January 31, 2020, 11:45:14 PM »
Yup and one model had a closed end swing arm that might have different dimensions, can never remember which one tho'
Re: rear wheel
« Reply #6 on: January 31, 2020, 11:54:39 PM »
Cb550/4 F1 & F2
Offline eight0
Re: rear wheel
« Reply #7 on: February 01, 2020, 07:55:15 AM »
I have the opposite problem, I have too much play. When i bought my F1 it had a series of different size nuts instead of the brake side spacer.
I ordered this part: 42313-323-010 which is too small. I think this is for a K Bike.
I've now ordered this one so I hope it fits! 42313-390-000
I found this in a post on the American site. Might be useful to you.
'74 550
Rear hub
  010   HUB, RR. WHEEL  42601-323-030
Backing Plate
       019  PANEL, RR. BRAKE  43100-374-000
Collar backing plate side
     008  COLLAR, RR.   42313-323-010
'76 550FBrake Panel
   003   PANEL, RR. BRAKE  43100-374-000
Hub
    009   HUB, RR. WHEEL   42601-323-030
Backing Plate Collar
    002   COLLAR, RR. (backing plate panel side)  42313-390-000
'78 550K
Collar Brake Backing Panel Side
    001   COLR, RR. PANEL SIDE   42313-404-000
REAR BACKING PLATE    002   PANEL, RR. BRAKE  43100-393-781
    002   PANEL, RR. BRAKE  43100-393-781 (replaces 43100-405-000)
    002   PANEL, RR. BRAKE  43100-393-781 (replaces 43100-405-010)
Rear hub
   007   HUB, RR. WHEEL   42601-404-000
Offline Philh550
Re: rear wheel
« Reply #8 on: February 01, 2020, 02:13:26 PM »
Mine has the closed swing arm.
Thanks for info will look into this.
Re: rear wheel
« Reply #9 on: February 01, 2020, 03:35:19 PM »
Closed is a F1 or F2 swinging arm. If the spacer on the drum side is 38mm and the hub and brake plate is correct, then it must be the sprocket side spacer that is too big.
Post some pictures and I can tell you if you have the right hub and brake plate  ;)
