Author Topic: Refitting Cb500 four carbs  (Read 7352 times)
Offline bobv7
« on: February 03, 2020, 01:24:08 PM »
Hi
I've taken mine off to get them sorted but getting them off and out was quite a struggle. What methods do the learned members suggest as the best way to refit them?
Cheers, Bob
Re: Refitting Cb500 four carbs
« Reply #1 on: February 03, 2020, 01:52:30 PM »
Loosen the  airbox.
Use a heat gun to soften the rubbers
« Reply #2 on: February 03, 2020, 02:22:37 PM »
Btute foce and swearing a lot plus new rubbers to cylinder head
« Reply #3 on: February 03, 2020, 02:29:20 PM »
A pot of red rubber grease helps no end. Plus the hairdryer or a pan of boiling water to soften the rubbers.
Offline GTB981
« Reply #4 on: February 03, 2020, 02:49:24 PM »
I`ve had the carbs off my 550 3 times in as many weeks now (long story). I have found you can get the outer airbox rubbers out from the bike after releasing the clamps. The 2 inner ones I pop into the airbox. Keep clutch cable clear and the carbs slide in and out from rhs. The rubbers on my bike are new and I also use red rubber grease. I perfected this method after many a grazed knuckle.
« Reply #5 on: February 03, 2020, 03:13:06 PM »
Very hard to re glue the 2 inner ones once you have retrieved them from the air box  ;)
Offline bobv7
« Reply #6 on: February 03, 2020, 05:24:19 PM »
Many thanks, they were a right bugger to get out.......and I've ordered some red rubber grease. Don't tell the wife! ;)
Offline GTB981
« Reply #7 on: February 04, 2020, 07:03:25 AM »
Re-glue ? Are they meant to be glued in ???
« Reply #8 on: February 04, 2020, 07:34:38 AM »
If you get a old set of rubbers and look in the groove, you will see the remains of a brown adhesive. It is also on the chamber to airbox rubber  ;)
Offline GTB981
« Reply #9 on: February 04, 2020, 07:36:19 AM »
Cheers for that. Kind of makes my method a tad impractical.
« Reply #10 on: February 04, 2020, 08:07:55 AM »
Are you sure it's glue? I always thought it was either vaseline or some sort of silicone paste. I see no harm NOT to glue them.
Offline bobv7
« Reply #11 on: February 04, 2020, 09:04:50 AM »
Mine aren't stuck and I noticed that the 2 outer ones have a pip on the edge and there is a similar one on the airbox. I assume that they are supposed to line up?
« Reply #12 on: February 04, 2020, 09:43:36 AM »
The 2 outer ones are handed.
Align the dots
Offline bobv7
« Reply #13 on: February 04, 2020, 10:59:41 AM »
Thanks for the confirmation :)
« Reply #14 on: February 04, 2020, 11:54:10 AM »
+1 with Oddjob, defo a stringy mastic / glue type substance. Removing the adhesive is one of the jobs that Trig gives me to do 🙄🙄🙄🙄 What a lucky girl I am 😁😁😁😁
