Author Topic: part no  (Read 6954 times)
MIKE550/4
part no
« on: April 17, 2009, 09:32:48 PM »
16010 323 305
carb gasket set
anybody tell me if this is suitable kit for carbs on my bike
78 550k
Re: part no
« Reply #1 on: April 18, 2009, 07:15:47 AM »
The 323 in the number indicates that it is for the carbs that originated on the 500 (ie the "627" carbs with the side-side screws on the carb top)
If your 78 is a K3 then you have the later (front-back screws on the carb top) and it's the wrong kit.
Your model number will be 404 in this case.
MIKE550/4
Re: part no
« Reply #2 on: April 18, 2009, 09:19:43 AM »
reason i am asking david silvers have no stock on carb gaskets for my bike ( apparently hard to get spares for the carbs )
seller on e bay who has 4 sets ( nos ) says will fit 550 as well
this site seems to confirm ... carbs are  keihin, 3 screws on front, 2 on back
http://www.cmsnl.com
link to e bay ..
http://cgi.ebay.co.uk/Honda-CB500-4-OEM-NOS-16010-323-305-CARB-PACKING-SET_W0QQitemZ290310262106QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item290310262106&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
last question if no good and ds has no stock anywhere else to go to ?
cheers mike
« Last Edit: April 18, 2009, 09:29:44 AM by MIKE550/4 »
MIKE550/4
Re: part no
« Reply #3 on: April 18, 2009, 09:25:48 AM »
superseded part no?
« Last Edit: April 18, 2009, 09:28:03 AM by MIKE550/4 »
Re: part no
« Reply #4 on: April 18, 2009, 12:24:01 PM »
Carb sets with 323 WILL NOT fit on the 77/78 550  you need :-
16010-393-305 or 16010-404-004
These also fit the CB750Auto which is even less common than the 550K3.
Last time i checked they were still available from Honda just not cheep
Offline matthewmosse
Re: part no
« Reply #5 on: April 18, 2009, 09:10:45 PM »
NRP do overhaul kits for lots of carbs, said they did them for cb550k3 when I asked a few years back when they were at Stafford show
MIKE550/4
Re: part no
« Reply #6 on: April 19, 2009, 12:43:28 PM »
have you got a link matthew
 ds have no stock and will not commit to a date they are coming back in
Re: part no
« Reply #7 on: April 19, 2009, 05:26:49 PM »
www.nrp-carbs.co.uk tel, 01618 328 646 Might also have inlet rubbers, not checked the site myself, not got time for the bikes at the moment as a landrover is clogging my shed :'(
