Author Topic: 1978 CB550 K3 "running" restoration  (Read 55995 times)
Offline SPR
  • 1972 500/4 K1
Re: 1978 CB550 K3 "running" restoration
« Reply #30 on: April 10, 2020, 12:42:58 PM »
Small things :)
Stand and side stand cost £20 in total for blast and powder coat in semi gloss
« Reply #31 on: April 10, 2020, 12:43:58 PM »
I’ll bet you were careful putting that spring on!
Offline SPR
  • 1972 500/4 K1
« Reply #32 on: April 10, 2020, 12:48:21 PM »
I learnt from the main stand - stretched the spring with pennies before I took it off so a piece of cake :)
Offline SPR
  • 1972 500/4 K1
« Reply #33 on: April 10, 2020, 03:52:53 PM »
So it would seem I’ve a leaking head gasket ....
1 Would this be a reason for the poor running at higher revs or is that me grasping !!
2 More importantly is head gasket renewal within the realms of novice ??
EDIT after researching .... No to both :(
Simon
« Last Edit: April 10, 2020, 04:25:58 PM by SPR »
Offline SPR
  • 1972 500/4 K1
« Reply #34 on: April 11, 2020, 10:14:43 AM »
So looking in to the head gasket requirements ...
This higher priced kit from David Silvers ....... any thoughts
https://www.davidsilverspares.co.uk/CB550K-1978-USA/part_356535/
Do I also need the 6 x 91318-300-013 hat bits ?
https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_91318300013/
Any other seals that are needed ?
Simon
« Reply #35 on: April 11, 2020, 10:32:22 AM »
Yes Simon, you need the hat bits (pucks or Pontefract cakes as they are know as.)
Offline SPR
  • 1972 500/4 K1
« Reply #36 on: April 11, 2020, 10:33:56 AM »
Thanks - I'll get both ordered
What is the best sealant to use for the hat bits ?
Then just need to find someone local :)
Simon
« Reply #37 on: April 11, 2020, 10:44:32 AM »
Simon
A light smear of Honda Bond on the pucks. Daunting I know but, why don't you do the work yourself?. Its a way of learning and there are all the resources you need on the forum in the way of advice and encouragement
Offline SPR
  • 1972 500/4 K1
« Reply #38 on: April 11, 2020, 10:49:07 AM »
Thanks ... I'll mull over having a bash but don't want to make things worse !!
« Reply #39 on: April 11, 2020, 12:08:12 PM »
All you need to do the job is a 3/8 drive socket set with 6 sided sockets and the manual downloadable from Alladins cave. Its the 500 manual with supplements for the differences on 550, for what you are doing no differences
Offline SPR
  • 1972 500/4 K1
« Reply #40 on: April 11, 2020, 12:27:33 PM »
Thanks Bryan
I've been reading the manual ... rather daunting in my case - I'm sure those with knowledge wouldn't bat an eye :)
Simon
« Reply #41 on: April 11, 2020, 01:19:26 PM »
The Honda manual is writen assuming you have a good basic knowledge, if unsure ask and i/we will explain it better-----maybe!!
Offline SPR
  • 1972 500/4 K1
« Reply #42 on: April 11, 2020, 01:22:46 PM »
I've ordered the bits and also picked up 4 genuine Honda carb gasket kits cheap  ... so may start with the carbs first !!
« Reply #43 on: April 11, 2020, 02:41:49 PM »
First thinhg with carbs is on the mixture scres should be a spring, tiny washer and very tiny O ring that all need to be there but get easily lost. O ring also gets stuck in the "hole" and needs to be removed.
Offline SPR
  • 1972 500/4 K1
« Reply #44 on: April 11, 2020, 03:54:22 PM »
Thanks Bryan
That is the same as the Harley ... I’ve read that 1 1/4 turns for the mixture ?
Simon
