Author Topic: Under tank wiring  (Read 2396 times)
Offline CornerstoneCB
Under tank wiring
« on: March 27, 2020, 12:24:37 PM »
Hi all,
Having some problems getting the fuel tank back on without disturbing wiring. I have checked my connections and remade some that were weak / worn. There does seem to be an abundance of wiring next to the left hand ignition coil that makes it very tight under the tank. Has anyone got any pictures of their loom in this area so i can see if it is appropriately routed or any other useful advice?
Thanks in advance,
Bikes:
1978 CB750 F1
2003 HORNET 600
1993 CB500
1980 CN100
1971 CB125
Offline Andrew-S
Re: Under tank wiring
« Reply #1 on: March 27, 2020, 03:48:55 PM »
Hope these help - they are of my 11/70 K1 survivor, so how the factory fitted it.
Cheers, Andrew
1972 UK XL250 K0 Motosport
1976 UK Z900 A4
2018 BMW R1200 GS
« Reply #2 on: March 27, 2020, 04:05:49 PM »
Thanks andrew.
Thats helpful. Can i ask, do the cables sit tucked in under the tank when its on or do they sit visibly under the base of the tank if you get my meaning?
Thanks again
Bikes:
1978 CB750 F1
2003 HORNET 600
1993 CB500
1980 CN100
1971 CB125
Offline Andrew-S
« Reply #3 on: March 27, 2020, 05:27:14 PM »
Thanks andrew.
Thanks again
These (pre-clean up) photos shows the large loom that goes to the headlight bowel and the small front brake light loom sit on top of the ignition switch bracket and are only visible where the loom(s) exit the tank at the headstock.
Edit: just noticed you have a 78 F1, not sure how different the loom is, but hope the photos help?
Cheers,
Andrew
« Last Edit: March 27, 2020, 05:33:42 PM by Andrew-S »
1976 UK Z900 A4
2018 BMW R1200 GS
« Reply #4 on: March 27, 2020, 05:45:36 PM »
Bikes:
1978 CB750 F1
2003 HORNET 600
1993 CB500
1980 CN100
1971 CB125
« Reply #5 on: March 27, 2020, 05:56:09 PM »
Didn’t the F1 have a junction box under the headlamp?
« Reply #6 on: March 27, 2020, 07:39:39 PM »
Yes it did, here is mine as I was putting it back together, this was the first photo that I could find I may have more if you want me to dig them out.
Here's one before I fitted the junction box.
« Last Edit: March 27, 2020, 07:44:44 PM by Spitfire »
« Reply #7 on: March 27, 2020, 08:00:56 PM »
Thanks all.
This was the condition i found mine in. Looks like it has been played with over the years and is now a bit tatty to say the least. I might be better off redoing it completely.
Thanks again for the help
Bikes:
1978 CB750 F1
2003 HORNET 600
1993 CB500
1980 CN100
1971 CB125
