Author Topic: Blown fuses  (Read 15608 times)
Offline Oggers
Re: Blown fuses
« Reply #30 on: April 05, 2020, 06:04:20 PM »
.and actually all 3 terminals on the regulator ground. I guess the green one should, but not the other two?
Re: Blown fuses
« Reply #31 on: April 05, 2020, 06:28:16 PM »
If the contacts in the reg box are closed the black conects to white which goes to the field coil then groung.
Disconnect the multi plug to the engine reconnect the reg and see if the black still grounds
Offline Oggers
Re: Blown fuses
« Reply #32 on: April 05, 2020, 07:25:55 PM »
Bryan - Wilco - just to clarify, which multiplug are we talking about here? Refer to Lobo's colour wiring diagram if you must!
Re: Blown fuses
« Reply #33 on: April 05, 2020, 07:44:13 PM »
I'm on the edge of my seat with this episode of 'Honda Wiring Problems Diagnostics'. It makes for far better watching than any of the crap on TV 😊😊😊😊😊
Re: Blown fuses
« Reply #34 on: April 05, 2020, 07:47:17 PM »
The one on the end of the engine lead 3xyellow, 1xwhite,1xgreen,1xlightgreen/red, 1xblue/red 7 leads in a 9 pin plug on electric panel.
Re: Blown fuses
« Reply #35 on: April 05, 2020, 07:50:31 PM »
Julie, at least this poster is listening, unlike some of our US friends enen on wing board
Re: Blown fuses
« Reply #36 on: April 05, 2020, 08:02:21 PM »
That's true Bryan. You are an excellent Tutor Bryan and I'm pleased I pointed Oggers in the right direction from the USA site to here.... 😊😊😊😊
Offline Oggers
Re: Blown fuses
« Reply #37 on: April 05, 2020, 08:06:12 PM »
Ok - disconnected the 9 pin plug connector. Same result.
Re: Blown fuses
« Reply #38 on: April 05, 2020, 08:41:18 PM »
Does the main loom plug into the electrical panel on a multi block? If so disconnect there and try black in loom again.
Offline Oggers
Re: Blown fuses
« Reply #39 on: April 05, 2020, 09:19:31 PM »
Lost me again I'm afraid! Main loom??? Electrical panel? Wiring is essentially as per Lobo' s diagram. I can follow that!
« Last Edit: April 05, 2020, 09:22:13 PM by Oggers »
Re: Blown fuses
« Reply #40 on: April 05, 2020, 09:54:14 PM »
That diagram is a schematic not literal.
Main loom is the big bunch of wiring along the bike front to back. Main panel is where the regulator, rectifier, flasher relay and solenoid are fixed.
I will look in my garage and see if i have a 550 one spare to look at, mostly i have 500 so not sure.
Offline Oggers
Re: Blown fuses
« Reply #41 on: April 05, 2020, 10:07:11 PM »
Ok understood. Rectifier has multiplug connector, regulator has 3 spade connectors - white black green, flasher relay two spade  connectors, solenoid as per wiring diagram. No large connector to main loom that I can see.
Re: Blown fuses
« Reply #42 on: April 05, 2020, 10:15:48 PM »
It's a 400 Bryan.
Offline Oggers
Re: Blown fuses
« Reply #43 on: April 05, 2020, 10:38:17 PM »
Forgive my presumption here, but surely that black connector and wire to the regulator must not be grounded. If so, it would provide a clear short path for the hot/feed wire direct from the ignition key, and surely blow the 15A fuse?
Re: Blown fuses
« Reply #44 on: April 05, 2020, 10:54:13 PM »
Any black wire, treat as 12V and deffo not to be earthed.  All earth wires are green.  Not green/yellow - green
