Author Topic: Wiring problem rev2  (Read 3021 times)
Offline Oggers
Wiring problem rev2
« on: April 08, 2020, 05:57:26 PM »
Right - think I will exhaust my stock of goodwill with you all, but here goes anyway
Blowing 15A fuse I think is sorted - fine, we'll see how it goes. Many thanks to all
Now connecting things up, and as far as I can see, everything has gone back exactly the same way - except regulator is disconnected.
Here's the thing
With the 15A and the 7A headlight fuse in place - all seems good. Ignition on and we have dash lights, indicators work, starter works etc - all good.
With the 15A, the 7A headlight fuse in place, and then the 7A tail fuse in place. Ignition on, and woe! All 4 indicators on permanently, but at least headlight and tail lamp light up!
Something clearly amiss....As ever any clues gratefully accepted. Short again - bad earth? Nothing obvious that I can see..
Re: Wiring problem rev2
« Reply #1 on: April 08, 2020, 06:05:08 PM »
Bad ground
« Reply #2 on: April 08, 2020, 06:09:56 PM »
As Bryan says.
If there’s a bad earth connection the current will earth via the other indicators. So all come on together.
You used to see this a lot in old cars where both indicators would flash. One maybe a little dimmer than the other.
Offline Oggers
« Reply #3 on: April 08, 2020, 07:04:10 PM »
To clarify if I may
As Bryan says.
Would I be looking at a bad earth on the tail fuse circuit then?
« Reply #4 on: April 08, 2020, 07:51:17 PM »
On mine, I added an extra earth wire from each indicator back to the loom.
It's a lot more reliable.
« Reply #5 on: April 08, 2020, 08:39:59 PM »
Could be taillight, clocklights or even headlamp you get to a point with load that it just has to gind a different path
Offline Oggers
« Reply #6 on: April 08, 2020, 08:42:06 PM »
Chaps
Found it. Poor earth bullet clocklight contact into a multi-connector in the headlamp shell.
Thanks for the steer.
« Reply #7 on: April 08, 2020, 08:52:30 PM »
Elecktrickery is wunnerfull.
Cant see it
Cant smell it
But if you touch it wrong it bites
Plus it does everything awkwardly
Youl be an exspert yet (ex as in used to be spert as in drip under pressure!)
