Author Topic: Crank Case bolt  (Read 4720 times)
Offline Seamus
Crank Case bolt
« on: May 03, 2009, 10:21:22 PM »
Lookin for a bit of help. One of my crank case bolts has sheared. I am fairly optiistic for the removal, but need a replacement. David Silver does not have them. Anyone with a spare? Happy to pay for the bolt and postage.
Looking for one of the 140mm long bolts that clamp the crankshaft. I believe tha there are 10 in total and most are 120mm.
Seamus
Offline bikerburke
Re: Crank Case bolt
« Reply #1 on: May 03, 2009, 11:24:51 PM »
HI seamus you can try  this link http://www.cmsnl.com/honda-cb750k1-england_model14355/partslist/E23.html   for your bolt ,i find there pretty good for the smaller parts for sohc hondas ,del takes about 4 days,cheers bikerburke
1972/3 cb500 ,shed to cafe racer in10 easy steps i hope :)
Offline Seamus
Re: Crank Case bolt
« Reply #2 on: May 04, 2009, 11:23:08 AM »
Thanks for the link. I'll give it a go. I have a bit of time before I need the bolt as I need to clean and repaint the cases.
Seamus
Offline Seamus
Re: Crank Case bolt
« Reply #3 on: May 04, 2009, 11:35:49 AM »
Had a look. Looks like they are not available any more. Part number is 90041-300-000 and it is the lower crankcase bolt. There are a pair of long ones (140 x 8mm)
Please have a look in your boxes of bits
Seamus
Re: Crank Case bolt
« Reply #4 on: May 05, 2009, 12:55:17 AM »
try www.westernhillshonda.net but email and ask as the site will always give you a price then it comes up unavailable days later
Offline mick
Re: Crank Case bolt
« Reply #5 on: May 19, 2009, 09:14:54 PM »
Hi Seamus,  are you still looking for this bolt? if so how many do you need 1 or 2 ? i 've been rooting through my spares and came across some  ;), cheers Mick.
Offline Seamus
Re: Crank Case bolt
« Reply #6 on: May 19, 2009, 11:19:56 PM »
Hi Mick, I am still looking. One would be pleanty ::) I have sent you A pm.
Apreciate you haveing a look.
Seamus
Offline Seamus
Re: Crank Case bolt
« Reply #7 on: May 20, 2009, 12:09:18 AM »
Hi Mick
Did my message work??
Seamus
