Author Topic: Copy of Original Honda CB550F Set Up Manual  (Read 2879 times)
Offline Oggie400F
« on: April 18, 2020, 02:24:48 PM »
I have scanned my original Honda Set Up Instructions Manual for the CB550F
Please see the link to my Dropbox file below.
https://www.dropbox.com/s/pgt8bojom8i1cmm/CB550_Set%20Up%20Instruction%20Manual.pdf?dl=0
I hope this works and that the scanned document quality is acceptable.
The image quality of the photos in original leaves a lot to be desired.
Hopefully this can be added to Aladdin's Cave if it can be of use to others.
Ian
Re: Copy of Original Honda CB550F Set Up Manual
« Reply #1 on: April 18, 2020, 04:41:01 PM »
Thanks Ian.
I have put a copy in Aladdin's Cave.
Steve
« Reply #2 on: April 18, 2020, 06:28:31 PM »
This is for a 550F usa unit. If you route the throttle cables as this PDF they will snap the cable mounts on a UK/ European as, the handlebars are too low for this route  ;)
« Reply #3 on: April 18, 2020, 08:47:27 PM »
Thanks Graham.
I will add a note about USA only.
Offline Oggie400F
« Reply #4 on: April 18, 2020, 08:54:05 PM »
Thanks Trigger for pointing that out and Steve for adding the note.
