Author Topic: cam cover  (Read 7585 times)
MIKE550/4
cam cover
« on: May 07, 2009, 11:13:33 AM »
in my rush earlier in the rebuild, have managed to mix up bolts for cam cover
anyone got a decent diagramn( exploded would be good ) for me to work this out , 550k
or pic with breather cover off ?
cheers mike
Re: cam cover
« Reply #1 on: May 07, 2009, 02:43:08 PM »
If you can get a parts book it shows the position of all the bolts and sizes in the description
Re: cam cover
« Reply #2 on: May 07, 2009, 05:28:32 PM »
I have a parts book for the K3.
Attached a scan of the relevant pages.
Let me know if you need any more.
Steve
MIKE550/4
Re: cam cover
« Reply #3 on: May 07, 2009, 09:55:43 PM »
cheers steve that looks good,
any link to where you downloaded that from ?
Re: cam cover
« Reply #4 on: May 08, 2009, 07:13:27 AM »
I scanned it from my own copy of the parts book.
It'll take time but I could scan the whole document if you like (not loose leaf and 77 pages unfortunately)
MIKE550/4
Re: cam cover
« Reply #5 on: May 08, 2009, 08:50:36 AM »
that would be good steve
Re: cam cover
« Reply #6 on: May 08, 2009, 09:23:02 AM »
I'll try to do it over the weekend and put up on my website for download.
I also have the parts book for the CB550F2
MIKE550/4
Re: cam cover
« Reply #7 on: May 08, 2009, 01:26:35 PM »
started this today after work got 2 questions
i am certain some of bolts are wrong on this bike and a couple missing
outer bolts ( 4 corners ) can someone confirm what size they are supposed to be,
also the front 2 as you sit on bike in the middle, next to tappet adjustment holes
also the tappet arms, they all move freely up and down apart from 1
as you sit on bike second left at front ( is this normal )
have a pic again
Re: cam cover
« Reply #8 on: May 08, 2009, 03:35:26 PM »
Outer 4 corners should be 6 x 25 pozi head screws, well not pozi but japanese phillips, DONT put allen screws in as the tappet caps will catch.
Front two that dont go through the breather are 6 x 32 and those that do are 6 x 65 again pozi heads.
There will always be at least one rocker arm that is trying to open a valve even with the screw backed right off.
