CB750
K7 wiring
Topic: K7 wiring (Read 3914 times)
corascate
Newbie
If you can’t make me skinny, make my friends fat
K7 wiring
April 24, 2020, 05:32:55 PM »
Hi all can any body help me with this wiring green with red trace from starter solenoid where does it go to.
Black with red trace where does it go to see attached pics
I have took a pic with my phone but when I try to post it . It says error file size to big.
How do I post pics
Works if I use iPad?
Last Edit: April 24, 2020, 05:38:20 PM by Corascate
jamesw999
Newbie
Re: K7 wiring
April 24, 2020, 05:41:02 PM »
What year is the bike?
corascate
Newbie
Re: K7 wiring
April 24, 2020, 05:43:55 PM »
1977 us bike
corascate
Newbie
Re: K7 wiring
April 24, 2020, 07:15:06 PM »
Cheers oddjob
The grey wire I hadn’t even got that far but it will save me asking later the black and red comes out of the loom .
When I got the bike a couple of months ago the prior owner said if you tried to start it , it blew a fuse and so he bypassed the regulator. I changed the regulator and can only assume it was done at time of bypass.
I know very little on wiring other than changing like for like and checking colours.
When I turn ignition on the front light comes on but no back lights, could this be related?
Steve
corascate
Newbie
Re: K7 wiring
April 24, 2020, 07:27:26 PM »
When I get chance I will post a pic of the wiring under the white plug in the picture.
It is a bit of a mare
S
corascate
Newbie
Re: K7 wiring
April 24, 2020, 07:55:26 PM »
Here’s the other side of the white connector block
corascate
Newbie
Re: K7 wiring
April 25, 2020, 08:36:54 AM »
im gonna have to find a new connector block and wire them in properly. there must be a suitable item available somewhere ,, hopefully one where you cann assemble the wires to the terminals and then push the terminals into the connector block. i have seen smaller versions on some boilers when wiring them in.
bruxby-clive
SOHC Associate
Re: K7 wiring
April 25, 2020, 09:26:05 AM »
You should be able to get a replacement that fits from here
https://www.vehiclewiringproducts.co.uk/
I used them to create a complete new harness for my KH250, including plugs and sockets that matched items I was reusing.
Just because you are breathing, doesn't mean you are alive.
corascate
Newbie
Re: K7 wiring
April 25, 2020, 10:51:12 AM »
Thanks for that bruxby Clive it’s perfect, I thought there had to be someone out there , but these are exactly what I want. Thanks again
Last Edit: April 26, 2020, 10:28:49 PM by Corascate
CB750
K7 wiring
