Author Topic: centre stand refit  (Read 11828 times)
MIKE550/4
centre stand refit
« on: May 16, 2009, 09:53:50 PM »
had some fun fittting this today
had it put on fine so i thought, then noticed the u shape hangar was cutting into my newly powder coated stand aaarghhh!
anyway have that sorted , centre stand is on and works fine can touch up the scratch
question if you look at pics there is a little black plate with 3 holes in it , have i fitted this correct and can some remind what this does
cheers mike
to steve d bit cleaner dont you think  ;)
pics to follow
« Last Edit: May 16, 2009, 10:06:30 PM by MIKE550/4 »
Re: centre stand refit
« Reply #1 on: May 16, 2009, 11:35:12 PM »
According to the parts book that plate should be underneath oh the RH side and is to hold the carb drains etc
MIKE550/4
« Reply #2 on: May 17, 2009, 10:22:03 AM »
cheers bryan will move it down to bottom of bolt,
hmmm one hole is much bigger than the other does it show how many drain tubes goes down each hole
Offline hobbers
  • Me
« Reply #3 on: September 28, 2014, 12:05:37 PM »
If you are still reading this - thanks for postng the image. I'm restoring a 550F1 and couldn't remember how to fit the spring - even thought I'd power-coated the half-moon bracket - doh!
Hobbers
Honda CB550 F1
Honda CBR600RR9
Offline mickwinf
« Reply #4 on: September 28, 2014, 05:55:58 PM »
Mike I think all the carb drains go through the big hole, the small hole is for the battery overflow if I recall correctly
Offline MikeM
« Reply #5 on: September 29, 2014, 08:49:00 PM »
unfinished project
Offline MickB
centre stand refit
« Reply #6 on: October 14, 2014, 06:58:49 PM »
Mike for what it's worth, why don't you get the nuts and bolts re-zinced seeing you've a new coat on the frame, it's not expensive and it'll make it look much better?
I'm restoring a 500 and had plenty of stuff rezinced and it looks like new.
« Last Edit: October 14, 2014, 07:05:13 PM by MickB »
« Reply #7 on: October 14, 2014, 07:02:42 PM »
Like it
Bitsa
« Reply #8 on: October 14, 2014, 07:04:40 PM »
MickB, So you have decided to come to the Dark side of SOHC ;)
Offline MickB
« Reply #9 on: October 14, 2014, 07:06:48 PM »
I just like seeing what's happening in the old dart. Seeing I came from there in chains.
« Reply #10 on: October 14, 2014, 07:13:11 PM »
Mick, you are older than i thought ;)
« Reply #11 on: October 14, 2014, 07:31:43 PM »
Where's the 'light' side then Trig?
« Reply #12 on: October 14, 2014, 08:19:44 PM »
At the end of the tunnel James ;D
« Reply #13 on: October 15, 2014, 06:56:38 AM »
Can't be cos some bsrd has knicked the bulb
Offline MickB
« Reply #14 on: October 15, 2014, 07:57:42 AM »
Mike I'm not sure if your spring and C thing is black or painted, here's mine re-zinced, certainly get the nuts and bolts done.
