Author Topic: 550F3 wiring harness  (Read 7603 times)
Offline Chris whit
« on: May 03, 2020, 11:41:38 PM »
Just completing full restoration on my 550F3 , ordered a replacement wiring harness from Silvers and noticed a lot of the the cable colours are different from the original and don’t match up with the handle bar switches etc .Should I order an original harness from CMS for the extra cost . What’s your experiences with aftermarket harnesses.
Re: 550F3 wiring harness
« Reply #1 on: May 04, 2020, 01:34:26 AM »
I can not even find a listing on Slivers site for a F3, only K3. The F3 was USA and is the same as a UK F2  ;)
Offline Chris whit
« Reply #2 on: May 04, 2020, 09:29:37 AM »
Probably why it’s different as I thought the one i got of silvers was for the F model , i will double check that the OEM one listed on the CMS site is for the F2 . Failing that i might try to refurb the original one .
« Reply #3 on: May 04, 2020, 09:45:48 AM »
I am a little confused here as, the picture of your bike has small indicators and the USA unit had larger ones  :o Does your bike have the VIN plate on the head stock or on the frame just behind the right side panel ?
I have just had a good look at the original loom on a F2 and then a good look at the wire colour on the aftermarket loom and the loom looks identical, with the same colour wiring .
Offline Chris whit
« Reply #4 on: May 04, 2020, 09:51:29 AM »
It has the vin plate badge on the frame next to side panel and also stamped on the frame
« Reply #5 on: May 04, 2020, 10:05:59 AM »
That is a UK CB550 F2 and it states that on the VIN plate and not a F3 from the USA so, not sure were you are getting F3 from  :o
Offline Chris whit
« Reply #6 on: May 04, 2020, 11:17:28 AM »
Ok must be me being a bit thick , checked on the frame number and I thought it was in the F3 range .
Offline Chris whit
« Reply #7 on: May 04, 2020, 11:20:46 AM »
So i am gathering that if the vin number starts with a 2 its then a F2 .
« Reply #8 on: May 04, 2020, 11:39:23 AM »
If your bike is a USA import it is a F3. If your bike is a 1st registered UK bike and was not registered overseas prior to 1st registration in the UK, it is an F2.
A USA F2 VIN starts with a 20 number, a UK F2 VIN starts with a 21 number.
« Last Edit: May 04, 2020, 11:54:05 AM by Nurse Julie »
Offline Chris whit
« Reply #9 on: May 04, 2020, 12:02:57 PM »
Thanks guys , but i am a bit confused about the wiring loom that I’ve bought from Silvers , it clearly states its for a F2 , i also bought a right hand switch gear genuine honda and the wiring colour does not match the switch wires .
« Reply #10 on: May 04, 2020, 12:23:22 PM »
Maybe it's not the correct frame for the rest of the bike Chris. I have a bike, a Mongrel, that by VIN has a K3 frame, which is correct but the rest of the bike is made up of CB550F engine and other parts and a big dose of CB 500K parts as well. But, if  anyone goes by my VIN they would say its a 550 K3.
Offline Chris whit
« Reply #11 on: May 04, 2020, 12:33:33 PM »
Just been checking the new wiring loom from DS and it seems that the green earth wire colours are now red and white on the replacement loom, very confused .
« Reply #12 on: May 04, 2020, 01:25:48 PM »
Just because you bought a GENUINE switch from slippery Sliver it, does not mean that it is original for your bike. Genuine just means it is a Honda Part and maybe from any other Honda Bike.
RED/white is live not earth/ground  ;)
« Reply #13 on: May 04, 2020, 01:35:24 PM »
Chris, the other side switch gear you bought from me was an original part, so the wire colours on that should have been the same as the corresponding wire colours on your loom, it that correct?.
Offline Chris whit
« Reply #14 on: May 04, 2020, 04:25:27 PM »
The loom is a really bad copy as they’ve used different coloured cables as per original , spot the earth colour . See photo of the rear of the loom .
