Author Topic: swingarm woes  (Read 7786 times)
MIKE550/4
swingarm woes
« on: May 21, 2009, 08:53:35 PM »
how did i miss this,  :-\
these are the sort of things that make me want to hang this up
got round to fitting swingarm,  arm is powdercoated to match rest of bike
if i am right they have powdercoated grease nipple ?
went to fit this tonight to find dent in side
also these bushes dont look great
give me some advice guys on the following
grease nipple (  simply unblock or renew?)
dent ok to use still swingarm? safety wise
bushes replace?  is it easy job
pics
« Last Edit: May 21, 2009, 09:33:10 PM by MIKE550/4 »
Re: swingarm woes
« Reply #1 on: May 21, 2009, 10:22:48 PM »
Unscrew nipple and replace with new, pennies to fix, would like tp see pics of steel sleevr before commenting on bushes
MIKE550/4
Re: swingarm woes
« Reply #2 on: May 22, 2009, 06:59:37 AM »
not sure what you mean bryan pic wise
do you want  more detailed pic of the inside of the round tube inside  where the main bolt goes for swing arm ? ie knock the sleeve out
this dent strangely seems to have appeared once i undone the grease nipple
is this swingarm still ok to use ( ie safety wise )
« Last Edit: May 22, 2009, 07:02:59 AM by MIKE550/4 »
Re: swingarm woes
« Reply #3 on: May 22, 2009, 07:29:32 AM »
Dent i wouldnt worry about those arms are way over engineered on the 500/550.
The steel sleeve that goes through the bushes and has the hole the long bolt goes through should slide out easily---if it needs to be "knocked" out you have a problem and its the outside of that tube in the area of the bushes i want to see
MIKE550/4
Re: swingarm woes
« Reply #4 on: May 22, 2009, 08:26:59 AM »
hmmm not sure what to do
will not slide out easily, does not seem to be any play , do you think i would be doing more harm than good if start using a drift to get this sleeve out
Re: swingarm woes
« Reply #5 on: May 22, 2009, 10:54:31 AM »
Nope because it HAS to pivot on that sleeve as the ends are trapped by the frame when the long bolt is tightened so it NEEDS to come out and be inspected/grease holes cleaned or you will be removing the swing arm again.
MIKE550/4
Re: swingarm woes
« Reply #6 on: May 22, 2009, 11:31:09 AM »
think that answers me, get it out, replace bushes new nipple re grease , dont want to be doing this twice  on same bike
cheers as usual bryan
Re: swingarm woes
« Reply #7 on: May 22, 2009, 03:04:47 PM »
Still need to see the sleeve as , tho' you wont believe it, the steel sleeve frequently wears more than the plastic bushes!!!
MIKE550/4
Re: swingarm woes
« Reply #8 on: May 22, 2009, 06:40:33 PM »
will report back when i get sleeve out with some pics
hopefully will get this out relatively easy
cant be any worse than that m/c clip ,haynes and clymer never mention, rust, dirt,grease and general crud
MIKE550/4
Re: swingarm woes
« Reply #9 on: May 23, 2009, 10:20:28 PM »
does not look too bad slight score on one, ( think this will be fine... bryan ? )
bushes were very brittle , did not take much to get them off
glad i changed them  now for all they cost...
hope the pics help others that am i putting up as this site has been a real help to actually share and gain knowledge
Re: swingarm woes
« Reply #10 on: May 24, 2009, 10:23:55 AM »
Yep, i agree, specialy considering the replacement cost. Make sure the grease holes are clear, plaster it in HMP grease and refit it then when fitted pump even more grease in through the nipple which, due to its location, is a right pain BUT needs doing every 1500 miles when oil is changed.
