Author Topic: Indicators will not flash  (Read 12673 times)
Offline Golfcarmad
Re: Indicators will not flash
« Reply #15 on: May 09, 2020, 10:52:23 PM »
All wired up with correct bulbs and engine running-still no luck
More bikes than sense!!
Honda 400/4 (almost fully rebuilt)
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Honda CBR500F (Import)
Francis Barnett Plover
Puch Maxi 2 speed (makes me smile)
Cb100n cafe racer
50cc scooter (now does 52 mph)
« Reply #16 on: May 10, 2020, 10:40:08 AM »
Are you using a 3 or a 2 pin flasher?
Offline Golfcarmad
« Reply #17 on: May 10, 2020, 04:19:26 PM »
Genuine 3 pin flasher from another 400/4
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
« Reply #18 on: May 10, 2020, 04:42:15 PM »
Only two reason for no flash if all bulbs lit
1 not enough load
2 duff flasher unit
« Reply #19 on: May 10, 2020, 04:57:01 PM »
I replaced mine with a 2 pin one.  I think it was about £8.  It does sound like the unit is duff.  You've got the correct load, and they all illuminate.   Csnt very anything else really.
Offline Golfcarmad
« Reply #20 on: May 10, 2020, 05:54:14 PM »
Thanks for advice everyone.
Looks like no indicators for time being.
Take care and stay safe.
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
Offline TrickyMicky
« Reply #21 on: May 10, 2020, 06:17:26 PM »
Working on the basis of "Any port in a storm", back in the early 1970's I worked part time in a motor accessory shop and we had a home made gizmo for checking customers' flasher units if they thought they were faulty. I checked one unit for a chap and it did not flash, just stayed permanently illuminated. As he was about to purchase a new unit, I went to pass him the old 'duff' one and dropped it on the hard floor. As a laugh I re-tested it and as you can guess it worked perfectly! Just a random thought, and after all, what have you got to lose? Stay Safe, Mick.
« Reply #22 on: May 10, 2020, 07:32:47 PM »
Ah yes, the old 'hurling it at the floor' trick
Offline Golfcarmad
« Reply #23 on: May 11, 2020, 12:10:51 AM »
I tried hitting with hammer!!
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
Offline THUNDERDOWNUNDER
« Reply #24 on: May 21, 2020, 08:48:36 PM »
Hi got the same problem (sort of ) indicators would flash a few times then freeze so put two pin flasher unit on (second hand ) and Indicators work a few times then freeze again . I gave unit a  flick (with finger ) and hey presto they work but for how long I don’t know !
Offline Winterfield
« Reply #25 on: May 22, 2020, 09:26:08 AM »
I had something that sounds similar - both the front and rear lights, and the console light would come on, but not flash.
The battery I was testing with was dead (i.e. not holding a charge). For testing my wiring loom I set up a bench power supply at ~13v and magically the indicators started flashing.
I just hope they continue to flash when I get a new battery.
« Reply #26 on: May 22, 2020, 12:06:17 PM »
Should do
« Reply #27 on: May 22, 2020, 01:12:36 PM »
Or have engine running or both
Offline Moorey
« Reply #28 on: May 22, 2020, 08:52:28 PM »
un crimp the unit and carefully remove the internals there is a earth wire from the internal part of the flasher to the alu body of the flasher and there should be a good contact between the alu body and the green terminal. if you look the green teminal on the underside of the insulated board makes contact with the can and it gets very corroded there. Give that bit a good clean. Hope that all makes sense.
« Last Edit: May 22, 2020, 08:55:41 PM by Moorey »
amx1992
« Reply #29 on: May 22, 2020, 09:45:00 PM »
Think he sorted it now, turned out to be bulb wattage
« Last Edit: May 22, 2020, 11:29:00 PM by amx1992 »
