Author Topic: Cylinder Bolt Caps  (Read 3695 times)
Offline oldtuggie
Cylinder Bolt Caps
« on: May 15, 2020, 02:06:45 PM »
Hi
Is it okay to use high temperature silicone to stick the rubber cylinder Bolt Caps down.
Thanks in advance
Re: Cylinder Bolt Caps
« Reply #1 on: May 15, 2020, 02:18:53 PM »
A smear of Honda Bond works well.
« Reply #2 on: May 15, 2020, 03:40:56 PM »
Cylinder bolt caps? Do you mean the rubber pontefract cakes(or pucks to the yanks) between head and cam cover
« Reply #3 on: May 15, 2020, 03:43:36 PM »
I read it as rubber cylinder bolt caps Bryan, so assumed he meant pucks, because he mentioned rubber 🤔🤔🤔
« Reply #4 on: May 15, 2020, 04:15:39 PM »
I was leaning that way Julie but prefer to clarify it
Offline oldtuggie
« Reply #5 on: May 15, 2020, 07:27:38 PM »
Yes the rubber Pontefract cakes
Offline oldtuggie
« Reply #6 on: May 15, 2020, 07:28:40 PM »
I've got Honda bond so I will use that
