Author Topic: CB750K6 UK Frame Name Plate / VIN Plate  (Read 5267 times)
Re: CB750K6 UK Frame Name Plate / VIN Plate
« Reply #15 on: May 24, 2020, 08:51:18 AM »
That's really helpful. The bike is a rolling chassis now so the last method will probably be the one I go for. Thanks again. Kind regards. Phil
I would do it the way James has said, by lowering the frame on the engine. This is the only way that you can guarantee  that you will not damage the paint  ;)
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #16 on: June 03, 2020, 09:33:23 AM »
You could also try this; I did it this way.
https://www.youtube.com/watch?v=obk7N1LDNYg
Offline Skoti
« Reply #17 on: June 03, 2020, 11:30:28 AM »
I found that If you first remove the cam box breather cover the motor fits in easier.
Also you're probably less likely to damage the frame paint.
BTW
Sean, thanks for the excellent Belfast to Belfast blog it's a fascinating read.
Skoti
1976 Honda CB750F1
Offline SeanFD
« Reply #18 on: June 03, 2020, 12:53:40 PM »
BTW
Glad you enjoyed it - and that someone actually read it  ;D
