Author Topic: forks refitting back into yolks  (Read 7373 times)
MIKE550/4
« on: June 04, 2009, 07:40:49 PM »
been struggling with this today, whats the knack guys  :-\
seems really tight to push through the yolk, but cant "open " the yolk holes any more
manuals just seem to say refit is reverse of removal ......rubbish  :D
Offline Dave M
Re: forks refitting back into yolks
« Reply #1 on: June 04, 2009, 08:11:57 PM »
It really is Mike.
Mine came out and slipped back in with no effort.
Dave
Melbourne.
MIKE550/4
« Reply #2 on: June 04, 2009, 08:42:00 PM »
yolks been powder coated, if that makes a difference,
dave have tried this for a couple of hours,  did not think it would be this difficult , forks fed from the bottom though bottom yolk, literally half an inch and they stop, tried spreading the yolks a bit wider but not much give , started to file the inside of yolks and gave up way to much hard work
these should just slide up if im right ?
« Reply #3 on: June 05, 2009, 07:31:03 AM »
They will slide up as long as the inside of the holes dont have powdercoat on them!!
Offline mick
« Reply #4 on: June 05, 2009, 09:01:20 AM »
you might have to get yourself a Dremmel in there to clean the powdercoat off  ;) cheers Mick.
MIKE550/4
« Reply #5 on: June 05, 2009, 11:08:29 AM »
right , well that was fun
not nice take all that off but there on, took an hour to dremel all the coating off and about 2 mins to re fit after
take it back refit is reversal
right wheels   :D
« Reply #6 on: September 06, 2009, 08:56:06 PM »
For future reference - be careful opening up the gaps as those things are brittle. I've seen them snap off before which can be a bit of a pain...
Offline Dave M
« Reply #7 on: September 07, 2009, 08:54:25 AM »
And very expensive!
Dave
Melbourne.
Offline matthewmosse
« Reply #8 on: September 07, 2009, 09:18:21 AM »
Better not to smash them cirtainly. I'd wonder if they didn't have a flaw in them if they snapped easily, perhaps from taking a knock in the past? I've taken appart some pretty ropey examples that have needed some perswasion and never seen one break.
« Reply #9 on: September 07, 2009, 05:05:42 PM »
Top ones break if you dont fit the shaped washer in the gap
