Author Topic: clutch replacement  (Read 4346 times)
Offline ader
Re: clutch replacement
« Reply #15 on: June 08, 2020, 09:54:09 AM »
I cracked the corner off the lifter plate, just into bolt hole, it seems to function ok. What is the potential damage if not replaced?
Offline legin101
« Reply #16 on: June 08, 2020, 12:00:58 PM »
now i have seen this infamous plate i can see why it happens, if the tension is taken off by all bolts at the same time then it will not break likewise when refitting take the tension by all bolts at the same time, now 3 bolt holes in good condition i would use a washer over the remaining hole and tighten to the specific torque.   that should be fine.
nigel
GT750L 1974
gsx750ET 1980
CB750F2 1979
MT10 2017
« Reply #17 on: June 08, 2020, 01:06:33 PM »
Forget torque just snug by hand
Offline Green1
« Reply #18 on: June 27, 2020, 07:22:09 PM »
I ordered the lifter plate from Goodbits on the 5th June and it arrived on the 8th so great service.
I have finally got around to fitting it today after work. I would go out on it to test my new clutch but I'v hurt my shoulder and can't twist the throttle  :'(
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
