Author Topic: CB750F2 sohc con-rod bolts  (Read 2439 times)
Offline SPEN10000
« on: June 07, 2020, 01:26:08 PM »
Hi all, i,m a new member asking a question about rod bolts for my CB750F" sohc Phil read replica. were can i get new con-rod bolts or can i re-use the old ones? any information would be welcome please.
Re: CB750F2 sohc con-rod bolts
« Reply #1 on: June 07, 2020, 01:50:12 PM »
Ordinarily and with no damage or reason to suspect they've been taken beyond normal operating conditions,  they are reusable and most engine builds don't replace.
They are torqued during installation within their elasticity limits,  so not taken through "yeald" as a stretched bolt application does.
13.0 to 15.9 lbs/ft rating from Honda manual.
« Reply #2 on: June 07, 2020, 01:50:39 PM »
Welcome to the mad world of the SOHC. If they are OEM they can be reused as long as they have not been over torqued  ;)
« Reply #3 on: June 07, 2020, 02:21:04 PM »
Welcome. We have a thriving set of PRR owners here. I'm sure they will be along soon.
Had one myself for a while:
Offline SPEN10000
« Reply #4 on: June 07, 2020, 03:28:22 PM »
Hi Guys, thanks for your help, it is most welcome. i am sure i will be asking for more help as the restoration goes along. :)
« Reply #5 on: June 07, 2020, 05:53:51 PM »
Welcome - enjoy the forum (I had one too!)
« Reply #6 on: June 07, 2020, 05:54:20 PM »
Picture Phil?
« Reply #7 on: June 07, 2020, 06:27:40 PM »
I'll try and dig one out Steve - I'll ignore the other comment Ken!
« Reply #8 on: June 07, 2020, 06:33:17 PM »
As requested
« Reply #9 on: June 07, 2020, 06:35:44 PM »
What brought it home for me about re-using con-rod bolts is Honda  tell you to Plastigage the bearings which involve torqing up the nuts and then disassembly possibly a couple of times so technically on final re-assembly they are used.
