Author Topic: IGNITION COIL FITTING  (Read 3202 times)
Offline Gromitdog
« on: June 17, 2020, 09:06:29 AM »
Good Morning all
Can anyone help me please I brought a Honda CB550K3 a while ago and it not running very smoothly when out on the road so i changed the plugs and done the timing and balanced the carbs (Well attempted too  ;D ) I am just wondering if I got the ignition leads back in the right order ?  I have had a look in the manuals and I can't find a write up or picture to tell me which coil outlet feeds which cylinder  I know L/H side coil feeds L/H side cylinders & R/H side coils feed R/H cylinders So which ignition leads go to which cylinder from the coils, Any guidance on this I would be most grateful
Also for further reference which NGK plugs are best for mid range use
Many thanks
Gromitdog  ;D
KEEPING IT SHINY SIDE UP IS ALWAYS A GOOD RESULT ON A RIDE OUT
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: IGNITION COIL FITTING
« Reply #1 on: June 17, 2020, 09:13:14 AM »
Hi I’m sure others will confirm this but if it’s the same as a K1, one coil is 1&4 and the other is 2&3.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
« Reply #2 on: June 17, 2020, 09:18:43 AM »
Morning gromitdog  :)
Yes as above,  one coil feeds both 1 and 4 cylinders,  and the other 2 and 3 doesn't matter which is which from a single coil as it fires both leads in parallel.  Just that the HT leads of 2+3 wouldn't normally reach the outermost two plugs.
To see which is which coil,  just trace the trigger wire from points marked 1+4 to the coil and fit to those cylinders.  Wires are usually yellow and blue.
Plugs are normally starting with ngk 8 heat range.
Offline peterengland
« Reply #3 on: June 19, 2020, 12:35:59 PM »
I use 7's in winter and 8's in summer usually as they are slightly cooler?? to be honest it doesn't seem to make much difference.
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Offline JezzaPeach
« Reply #4 on: June 23, 2020, 08:32:04 AM »
Pic attached
