Author Topic: USA Spec 550 four indicators  (Read 4451 times)
Offline oldtuggie
« on: June 17, 2020, 07:43:36 PM »
Hi
Going through things after a full rebuild and I've got a front indicator problem. The indicators come on with the ignition and stay on which is correct but do not flash, they have the same bulb fitted as the rear indicators which are single filament, am I correct in thinking that the front bulbs should be double filament.
Offline Erny
  • CB750K7 CB550K1
Re: USA Spec 550 four indicators
« Reply #1 on: June 17, 2020, 09:58:26 PM »
Yes, correct. Front have double filament, see pic, left is front, right rear.
Pics from diagram shows wiring. You must have 2 wires in front and 1 rear (plus ground of course)
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline oldtuggie
« Reply #2 on: June 17, 2020, 10:36:29 PM »
Thanks for the reply I took the bike on as a half finished project the frame and electrics all done I've rebuilt engine , gearbox etc.
I think the indicators have been replaced with pattern parts and the same fittings have been put on the front of the bike as at the rear and they won't take the double filament bulbs.
I will have to source the correct fittings or disconnect the permanent live feed and have them operating as the UK spec bikes do
« Reply #3 on: June 18, 2020, 07:31:32 AM »
You have to disconnect the "running lights" anyway to comply with UK rules. The front should connect to the solid blue and solid orange wires not the ones with white stripes
« Reply #4 on: June 18, 2020, 08:56:29 AM »
As a bonus you will have 16 Watts saved!
« Reply #5 on: June 18, 2020, 08:57:06 AM »
42 actually
« Reply #6 on: June 18, 2020, 11:15:13 AM »
42 actually
? He will need his blinker filaments, won't he?
« Reply #7 on: June 18, 2020, 11:24:18 AM »
Brain fart, he will only save 10w bulbs are 21/5 same as tail light
Offline Moorey
« Reply #8 on: June 18, 2020, 09:45:31 PM »
Running lights are now allowed in the  indicators as long as they don't interfere with the function of the indicator. Which they don't as when you indicate that side running light element goes off.
Offline Erny
  • CB750K7 CB550K1
« Reply #9 on: June 18, 2020, 10:47:08 PM »
Exactly, new bikes (Honda Africa Twin, new  retro CB650R/1000R) have them as standard...)
