Author Topic: TRICKLE CHARGER  (Read 8293 times)
MIKE550/4
TRICKLE CHARGER
« on: July 08, 2009, 01:46:25 PM »
can someone advise me what i need to keep batterys from going flat ...
will be 2 550's  f2 and k3
cheers
Re: TRICKLE CHARGER
« Reply #1 on: July 08, 2009, 01:52:23 PM »
You should be OK for over a month wihout as long as battries are OK and good idea to kickstart after they have been stood, also drain carbs.
When i was selling there used to be a thing called a Battery Tender which was about the size of a mobile charger and charged at less than 1/2 amp, dont know if they still exist or not
Offline matthewmosse
Re: TRICKLE CHARGER
« Reply #2 on: July 08, 2009, 02:05:01 PM »
Optimate battery charger does this but at
MIKE550/4
Re: TRICKLE CHARGER
« Reply #3 on: July 08, 2009, 02:31:02 PM »
been on hols for 2 weeks and barely turns over, so need a charger ,
will look up this optimim, take it you disconnect battery and hook this up for couple of hours
also how to drain carbs,
Re: TRICKLE CHARGER
« Reply #4 on: July 08, 2009, 02:36:33 PM »
both optimate (what I've got) and accumate can be left attached to the bike all the time (other than when you are rideing it, and will montor and maintain the battery all year long if need be
MIKE550/4
Re: TRICKLE CHARGER
« Reply #5 on: July 08, 2009, 03:13:23 PM »
work for rs components
am i on right track here , pick us out a prt no thats suitable
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=0549716
« Last Edit: July 08, 2009, 03:15:03 PM by MIKE550/4 »
Re: TRICKLE CHARGER
« Reply #6 on: July 08, 2009, 06:47:44 PM »
Optimate has a 24 hour cycle so a couple of hours will not really help.
Look into an Optimate III from eBay - the new Optimate IV is very complicated and another
