Silvers electronic ignition
Topic: Silvers electronic ignition (Read 6636 times)
RGP750
"always look on the bright side of life"
July 03, 2020, 06:20:53 PM »
Finally got the 500 pretty much finished.
I bought Silvers electronic ignition as had a lot of good reports.
The instructions are not brilliant but following as well as I can I can't get it to do what it is supposed to do .
Am I correct the light should NOTbe on when you line up the 1/4 timing market should only come on when you rotate the back plate anti clockwise?
Mine is on and doesen't go off unless you turn the crank
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Johnny4428
Re: Silvers electronic ignition
July 03, 2020, 06:38:05 PM »
Hi, I fitted one short ago after about half turn of crank to activate the light comes on then goes out and the next time the light comes on continuing the clockwise rotation the 1,4 should line up if correctly adjusted. That’s probably as clear as mud, but mine seems to be running fine. Good luck! Johnny.
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
July 03, 2020, 06:40:25 PM »
Difficult to say Rich.
Us “electronics boys†can’t help unless we know what the light is supposed to indicate.
RGP750
July 03, 2020, 06:44:48 PM »
I'll take a photo of the instructions and see how you read it Steve
1973 CB175
1972 CB175
1969 750 K0
RGP750
July 03, 2020, 07:04:30 PM »
Here you go ,how to you interpret it?
1973 CB175
1972 CB175
1969 750 K0
Johnny4428
July 03, 2020, 07:16:44 PM »
I didn’t have any success setting by instructions either, I just kept rotating crank and resetting plate until it was set.
It is the same as mine. The light comes on with supply interruption, ie spark time.
RGP750
July 03, 2020, 07:37:28 PM »
So basically you set where you think it should be and keep moving until the marks and light match up .
1973 CB175
1972 CB175
1969 750 K0
SteveD CB500K0
Administrator
July 03, 2020, 08:09:02 PM »
“The LED is lightened when the crankshaft rotates halfâ€
I rest my case.
RGP750
July 03, 2020, 08:45:36 PM »
Understand that Steve but Lines 16 says ' turn back plate counter clockwise until the light comes on" trouble is it is already on and you can turn as far as you like it doesn't go out .
Anyway just sorted it as previous post suggested, ignore Chinese instructions and do what you think, worked a treat, just need to balance carbs,
Happy days .
I'll put up pictured shortly Steve so you can see 'Goldie" in all her glory.
Cheers Rich
1973 CB175
1972 CB175
1969 750 K0
Johnny4428
July 03, 2020, 09:19:48 PM »
That method worked for me. I just got confused by the instructions, (I quite often do mind)😂😂
RGP750
Reply #10 on:
July 03, 2020, 09:49:35 PM »
Thanks Johhny
Instructions are pretty poor at the least.
1973 CB175
1972 CB175
1969 750 K0
triplE675
SOHC Associate
Reply #11 on:
July 09, 2020, 12:11:09 PM »
Hi Rich,
I put one on my 500k3 because
Oem points are so expensive together with how long it takes to set them up.
20 mins fit and forget.
Sent from my moto g(7) play using Tapatalk
paul G
Reply #12 on:
July 09, 2020, 12:36:57 PM »
Seems a bit strange to me putting all those vulnerable electronic components in an environment like that.
Can't see the rating on that electrolytic cap but that will be the first thing to go if it gets too hot and dry's out
bobv7
SOHC Expert
Reply #13 on:
July 09, 2020, 01:12:34 PM »
I fitted mine a while ago but it doesn't seem to have much built in adjustment, in fact it's rotated round as far as it will go but the bike seems to run fine.
MrDavo
Reply #14 on:
July 09, 2020, 02:32:26 PM »
Luddite here, I stick to old fashioned clockwork points, because if I understand how something works I might be able to fix it when it breaks.
As far as I'm concerned, electronics work or they don't, the only fix is a new unit. Which system is more prone to break down in the first place is the debatable bit - no wearing moving parts versus unnecessary complexity. Pre unit BSA twins, for example, you can set the timing with a pencil and a fag paper - you mark the pencil with the required BTDC measurement when it is in the spark plug hole and set the magneto so it lets go of the fag paper at that point.
