Author Topic: CB750K6 restoration project. Disc cover fowls on disc  (Read 2572 times)
Offline Phil9886
« on: July 05, 2020, 01:12:03 PM »
Hi. Hoping someone can help me. I'm at the very end of a restoration project on a K6 and tried to fit the disc cover - but it fowls on the disc. The disc appears to be the right size as it just reaches the top of the pads. I'm wondering if I have a pair of CB 400 lower fork sections - which could have the mounting brackets for the cover in a slightly different place?  Or am I missing something easy?  Everything else appears to line up / bolt on perfectly.
Offline Phil9886
Re: CB750K6 restoration project. Disc cover fowls on disc
« Reply #1 on: July 05, 2020, 01:15:00 PM »
Or even fouls :-)
« Reply #2 on: July 05, 2020, 01:36:31 PM »
Or even fouls :-)
Come on.
That's a poultry complaint
« Reply #3 on: July 05, 2020, 01:56:17 PM »
It should go on the large bolt at the lower end of the pivot pin
Offline Phil9886
« Reply #4 on: July 05, 2020, 02:30:06 PM »
Yes - that's where I'm trying to fix it. The more I look at it the more I'm thinking I've got 400 forks on it. Does anyone have a measurement from the center of the front axle to the point where the rubber gator starts on the the LHS lower fork section?  That would be really helpful. Thanks. Phil
« Reply #5 on: July 05, 2020, 02:40:59 PM »
Is there a caliper mounting on the other slider?
Offline Phil9886
« Reply #6 on: July 05, 2020, 02:46:40 PM »
Yes there is. It came with a twin disc conversion - I've left the RHS disc off. So I guess it must be a set of 750 forks. Maybe the disc is non standard and diameter slightly too large? Anyone know what the diameter of a standard disc is? Thanks again. Phil
« Reply #7 on: July 05, 2020, 04:43:10 PM »
Not off hand. Are you sure the cover is off a 750?
Offline Phil9886
« Reply #8 on: July 05, 2020, 05:03:46 PM »
Yes. Bought from CMSNL. There was no cover on when I bought it though. I'll check the disc diameter. That's likely to be the problem. Cheers. Phil
