Author Topic: Petseal in tank  (Read 2718 times)
Offline Brian59
Petseal in tank
« on: July 11, 2020, 09:49:28 PM »
I have put Petseal in my petrol tank a few years ago, it is now starting to peel off inside the tank. What is the best thing/way to remove this flakey mess?
Also, does ethanol (in petrol) attack the old petrol pipes and the pipes between the carbs?
Offline motty
Re: Petseal in tank
« Reply #1 on: July 12, 2020, 08:59:23 AM »
In my experience, unless you get ethanol proof pipes, the pipe will harden and make it difficult to remove
Sent from my Moto E (4) Plus using Tapatalk
Offline SteveW
Re: Petseal in tank
« Reply #2 on: July 12, 2020, 09:01:02 AM »
Acetone removes tank liner
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Petseal in tank
« Reply #3 on: July 12, 2020, 10:23:43 AM »
I have similar problem in my Matchless restored 22 years ago, can’t even remember what type of sealer/liner it was but it’s not looking so good now. Will have to be stripped sometime. Good winter job!
« Last Edit: July 13, 2020, 01:31:28 PM by Johnny4428 »
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: Petseal in tank
« Reply #4 on: July 12, 2020, 11:10:28 AM »
If you end up using POR15 cover all skin use a mask and a fan to blow fumes away from you. I ended up with a rash.
Modern fuel hose I bought from DSS is pricey but super elastic and stays on without clips.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline Brian59
Re: Petseal in tank
« Reply #5 on: July 16, 2020, 07:40:25 PM »
Thanks for all your responses
