Author Topic: CB750 F2  (Read 5946 times)
Offline blackeagles
CB750 F2
« on: July 12, 2020, 01:24:10 PM »
following on from my earlier post about drive chain noise and syncing the carb to help....i have been having a little trouble setting them up and i just noticed, looking at an illustration of the pd42 carb, that the 3 pipes that connect the acc. pump to each carb seem to have a restrictor in each (is it part number 16026-393-004 or maybe that is what joins the carbs fuel supply together).  no surprise when i took the old pipes off they didn't have such a restrictor so i have not used one....is that likely to cause an issue with setting the sync or the slow running????
bearing in mind they cannot be obtained (as far as i know)
« Last Edit: July 12, 2020, 01:33:11 PM by blackeagles »
Re: CB750 F2
« Reply #1 on: July 13, 2020, 10:47:21 AM »
I think it has the potential to bleed through and affect mixture when not intended,  whether it's doing that I can't immediately think of a competent and easy check.
Ordinarily the system is supposed to work as requires pressure to force the fuel out only when pump breaches the restriction,  so you could see a pathway if not there as it should not contribute under any non pumped condition.  That's true of any accelerator pump design as you'd not want vacuum pulling fuel through that's essentially unplanned.
We'll need to try to come up with a logical method to isolate or prove the affect and affect a cure if that's the case.
Offline blackeagles
Re: CB750 F2
« Reply #2 on: July 13, 2020, 06:34:27 PM »
i have had another close look at a number of diagrams online and the 3 acc. pump rubber hoses between the carbs do not seem to show a restrictor to fit into them.
i got the idea they may need such a restrictor(s) as i came across a post on this site that mentioned there were "3 brass restrictors per pipe" and i am guessing that if they actually exist they will be unobtainable or, of course, i may have misread the post (not that i can find it again anyway).
« Last Edit: July 13, 2020, 06:52:16 PM by blackeagles »
Re: CB750 F2
« Reply #3 on: July 14, 2020, 05:35:44 AM »
They were just open brass pipes in mine not restrictors.
Re: CB750 F2
« Reply #4 on: July 14, 2020, 09:50:58 AM »
Have you a local mot station that would be willing to give you a set of exhaust emission readings to see where you are?
Thinking along the lines of setup as best you think you can obtain,  then get a test with it warmed up to confirm where it's sitting from analysis.
Offline blackeagles
Re: CB750 F2
« Reply #5 on: July 14, 2020, 10:38:21 AM »
an interesting idea and i assume my 'local' has a gas tester although i have not seen one when there.
i just read a post you did back in 2017 where you were quoting 'honda manual' about syncing then adjusting slow running no 2 screw to max rev then back 100rpm, readjust and then do the others likewise.  i cant say i have tried this, just set them all the same setting so maybe i will try although i have got to get the syncing right/checked first and find an electronic rev counter to do the final adjusting as i doubt the bike one is accurate enough (or maybe it is goo enought as i'm not looking for the last bhp!)
« Last Edit: July 14, 2020, 10:44:14 AM by blackeagles »
Re: CB750 F2
« Reply #6 on: July 14, 2020, 11:47:28 AM »
The car mot equipment usually has to have a decent calibrated meter so maybe a scource if they are friendly  :)
Was my previous post (referred to  by you above) the one with a photo from the Honda manual in it?
The routine is their official one and it does indicate that the factory carries out this routine during production to give accurate running at low speed.
They also state not to move the screws in normal service,  but only re-established them after carb rebuild.  What it's doing is normalising each individual cylinder's combustion process until they are equal,  irrespective of the final screw position as it's combustion parity that counts in smooth running.
It's a very neat routine that effectively "micrometer" adjusts the low speed running to refine it,  but as you point out,  main throttle syncing needs to be correct before this stage.
I think its just as accurate if you sync them first with Bryan's bench method,  you don't need gauges for it this way.
Rev counter,  if you've a DMM ( digital multi meter) that reads frequency,  that will give you an accurate rev counter when connected to one points set as one revolution produces one pulse.
Offline blackeagles
Re: CB750 F2
« Reply #7 on: July 14, 2020, 12:17:17 PM »
i don't think it had a pic, just a requote from a post you did earlier but it still hold good today and something i will try.
bike is not fully insured so can not run it down the bypass to test out the changes, or go to the local garage, although i don't think i am that far away as things stand.  i am going to reset the gauges by using one cylinder so they should all  show the same afterwards (i did do the bench set but it ran badly so may have screwed that up) and anyway i guess they only need to be close not necessarily spot on - i may see if i can borrow carbtune pro or such if i feel it will help.
Re: CB750 F2
« Reply #8 on: July 14, 2020, 12:51:40 PM »
The exhaust analysis would be to assess if you've a basic mixture problem in regard to uncontrolled fuel faults.  By reading O2 C0 and HC, it would be clear if there's an underlying issue.
It won't be necessary if you can work through and get where you need conventionally though.
Re: CB750 F2
« Reply #9 on: July 15, 2020, 07:36:37 AM »
There should be a non return valve in the accelerator pump body (the removable cap)  that prevents fuel flow until the diaphragm is pumped, could that possibly be stuck slightly open. They are still available from CMS. https://www.cmsnl.com/honda-cb750f2-super-sport-england_model14689/diaphragm-pump_16021393004/#.Xw6z8puSmUl
There are no restrictors as such in mine just small bore brass tubes inside rubber tubes (I assume to prevent the rubber tubes collapsing). There's a small air vent in the side of the carb bodies, if one or more is blocked it's impossible to get even running. The vent is hard to see and cannot be cleaned with carbs assembled. Also, I have never seen that vent mentioned in any manual.
My F2 runs spot on after the second carb rebuild to clean the vents, where previously it would not balance up at all. And don't forget, the air screws work in the opposite direction to earlier 750's.
« Last Edit: July 15, 2020, 08:51:46 AM by royhall »
Offline blackeagles
Re: CB750 F2
« Reply #10 on: July 15, 2020, 10:40:20 AM »
as far as i can see the acc. pump non return valve is ok.
you say "just small bore brass tubes inside rubber tubes" if you are talking about the 3 rubber tubes connecting the acc. pump supply to each carb then i don't have any of these bass tubes in my rubber tubes and these may be the 'parts' i saw mentioned.  they do not show in any diagrams i have seen - are they likely to allow too much fuel into the carb each time the acc.pump works??
Re: CB750 F2
« Reply #11 on: July 15, 2020, 12:35:44 PM »
I think they are just there to cut down the amount of fuel held in the pipes and stop the pipe collapsing. The diaphragm will only pump it's volume whatever the setup.
Offline blackeagles
Re: CB750 F2
« Reply #12 on: July 15, 2020, 01:30:51 PM »
ah, i should have known that!
Re: CB750 F2
« Reply #13 on: July 15, 2020, 02:40:11 PM »
Correction, stops the pipes expanding under diaphragm pressure not contracting. Senior moment.
Offline blackeagles
Re: CB750 F2
« Reply #14 on: July 15, 2020, 02:59:11 PM »
it comes to us all!!
