Author Topic: 500 Four ignition timing  (Read 7866 times)
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: 500 Four ignition timing
« Reply #15 on: July 15, 2020, 08:14:21 AM »
A lot of fiddling but I eventually realised how much difference the points gap makes to the timing. I find I need to set the left set closer to 0.4 than 0.3, otherwise the right set can’t advance enough to reach the F mark when the static light comes on.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline bobv7
« Reply #16 on: July 15, 2020, 08:36:28 AM »
Must admit that I was always a bit over the top about setting the points precisely to a fixed gap, but when you actually look at the wide tolerance range it does make setting the timing spot on easier. Now I just set the timing then measure the gap. This also compensates for the wear on the advance retard cam.
« Reply #17 on: July 15, 2020, 11:26:59 AM »
On my bike that has OEM parts, when I have the breakerpoints exactly where they are supposed to be, they are both in the middle of the adjusting range. Then, after I have done the timing, also the plates are both in the middle of the adjusting range. I'm not saying this goes for any CB500/550, but these are my results with original TEC parts. To adjust the timing, I only have to readjust the breakerpoints gap and all is fine.
Offline JezzaPeach
« Reply #18 on: July 15, 2020, 12:48:29 PM »
Good points, no pun intended, a lot less fiddling.
Offline bobv7
« Reply #19 on: July 15, 2020, 04:04:41 PM »
Just come back from a test run, new fuel lines and complete contact breaker set up. The new back plate needed some fettling with fine emery cloth to get it to fit in place and move easily, not a surprise with pattern parts I suppose but the bike now runs as smoothly as any 40+ year old does. Now got the rest of the week to recover!
Offline JezzaPeach
« Reply #20 on: July 15, 2020, 05:31:11 PM »
