Author Topic: Mystery switch  (Read 3301 times)
Offline billdn
Mystery switch
« on: July 16, 2020, 10:57:35 AM »
Does anyone know what this does, it is shown as "rectifier assembly" on parts list but as I'm changing to rectifier/regulator combined unit should I remove this also? It's not shown on wiring diagram and has two wires from it , that are both red/green -also not on wiring diagram. I don't want to install new unit and blow it up or if I remove will that cause damage to new unit either.
Offline billdn
Re: Mystery switch
« Reply #1 on: July 16, 2020, 11:01:11 AM »
Arrgh! Don't know why my pics always come up wrong way round! It's sited directly below indicator relay and to l/h/s of starter switch on left side panel
Offline billdn
Re: Mystery switch
« Reply #2 on: July 16, 2020, 11:03:49 AM »
Parts diagram showing location
Re: Mystery switch
« Reply #3 on: July 16, 2020, 11:22:25 AM »
Starter safety circuit diode not a rectifier
Offline billdn
Re: Mystery switch
« Reply #4 on: July 16, 2020, 11:25:48 AM »
Bryan J many thanks so need to remove it !
Offline Deano400
Re: Mystery switch
« Reply #5 on: July 16, 2020, 12:05:04 PM »
You need to keep it. It's part of the circuit that stops you starting the bike if it's in gear unless the clutch is pulled in.
Re: Mystery switch
« Reply #6 on: July 16, 2020, 06:24:54 PM »
Wot Dean said.  ⬆️
